Will my EVGA 500w W1 fail?
Go to solution Solved by mariushm,
BR series is a bit better than W1, but they're both still bronze efficiency, cheap (budget) power supplies.
If you don't mind that it's not modular,  Thermaltake Toughpower GX2 600w gold efficiency is $65 : https://amazon.com/dp/B087CDR14Z
You get gold efficiency, 5 years warranty, around 550w on 12v ... it's much better than those EVGA models.
A second option would be this Antec NeoECO Gold Zen Series NE500G Zen 500W ATX12V 2.4 80 Plus Gold Certified Non-Modular Active PFC Power Supply  at 70$ : https://www.amazon.com/dp/B0817DXRPX?th=1
It's good internals  but the thermaltake has better value (600w vs 500w for 5$ less)
I'd say it would be worth returning the 500 W1 for either of the two above.
I have been making a pc recently and I bought a 500w EVGA W1 power supply to use. It had solid reviews on the store page. However. After some changes in my plans I may want to buy a rx 590 to use in my system (I was orignaly going to use an old 1060 i had but a 590 looks better). Seeing as this will reach up to 500 watts of power combined with my i3-12100f I'm not sure if it will work anymore. I can still return it on amazon, but I don't even know of any suitable replacements that won't bankrupt me. I then became more concerned after I saw people saying it might fry my components. I know this topic is all over the place but I just need some help figuring it out.
tldr: Will my 500w EVGA W1 blow up? If not will it even handle my i3-12100f and rx 590?
Those parts don't consume anywhere near 500W. I run a 5700XT and R5 5600 with a EVGA 500W W1
Ah ok, I used new eggs wattage calculator.
Should I step up my budget to a 5700 xt? Its not that much more and the performance is much better. although I doubt my i3-12100f will keep up.
You're listening to the wrong people, they told the same thing for my old PSU in my previous build, it worked great and works great to this day.
Ryzen 5 5600x | Gainward RTX 3060 Ti | 2x16GB 3200MHz | Samsung 980 1TB | 1 TB WD Blue | 120GB A400 Kingston Gigabyte M2 NVME 512GB  | BeQuite Straight Power11 80+ Gold 750W
The w1 is super low end. Its F-tier on the psu teir list. It probably has enough wattage its just that its really low quality and I wouldnt expect it to be reliable.
https://cultists.network/140/psu-tier-list/
PC Specifications: Intel i7-13700K 5.6GHz All core, 5GHz Ring, E-cores and HT disabled, 1.475v, Medium load line calibration | MSI RTX 4090 Gaming X Trio | Arctic Liquid Freezer II 360 + Thermal Grizzly contact frame | 2x16 G.Skill Trident Z5 7200MHz CL32 1T 1.435v (Tuned Subtimings, Hynix A-Die) | Gigabyte Z790 AORUS Elite AX | Windows 10 Home 64-Bit EVGA SuperNOVA 1000 T2 Phanteks P400A (black non-rgb version, arctic p12 fans 3 intake, 2 exhaust) Crucial P1 500GB (Boot drive), Samsung 870 EVO 2TB
Peripherals: Razer Huntsman V2 Full size wired with linear optical switch | Logitech G502 Hero Monitor: Asus TUF Gaming VG279QM 1080p 280hz 27" ips (Calibrated)
Audio Setup: STAX SR-009S | STAX SRM-400S | Schiit Modius E Multibit | Using balanced connections
Microphone: Audio-technica AT2020USB+
As long as it wont explode I think it will be fine for me. I've had low end stuff in the past and it doesnt fail nearly as often as I've been lead to believe.
Newegg calculator probably goes by the video card manufacturer recommendations, which are not based on the actual power consumption of the video card.
A video card manufacturer has no idea how much power other components in your computer will use, so they just pick a number that's guaranteed to give them the least amount of stress as in as few as possible tech support calls / emails, least RMAs and so on.
A RX590 consumes maybe up to 230-250 watts from the 12v output of the power supply. For very short  bursts (like for 5ms every once in a while), it may consume up to 300w.
A 5700XT consumes up to around 220 watts, with the same peaks of up to around 250 watts for very short periods of time, like 5-10ms, and mostly in benchmarks.
Your 12100F consumes maybe up to 50 watts, from the same 12v output of the power supply.
The rest in your system is very low power ... fans consume 1-2w from 12v, chipset and ram is powered from 3.3v and 5v output and usually it's little, 5-10w for chipset, 2-3w per stick of ram, a ssd consumes 3-5w during writing to it, less than 1-2 when reading
So in the case of a 5700XT, any power supply that can supply at least 250w (video card)+50w (cpu) + 25-50w (for anything else) on the 12v output would work for you
The 500w W1 can supply that much power ... but it's not a great choice for such video cards because they're quite inefficient at such high power consumption, which means they'll produce a lot of heat, and a power supply like W1 is the kind where they cut corners and use less efficient components to make it very cheap and good enough to just last the warranty time and a bit more, and they're hoping they're gonna be used in equally cheap systems that won't use such power hungry video cards.
If the cheap fan it's supplied with fails while you're gaming, there's a good chance the power supply would not be able to handle the heat produced due to the poor efficiency and the power supply could break down.
between 5700xt and rx 590, it makes sense to go with 5700xt as it's newer generation and will have longer support in drivers in the future.
Don't make your purchase choices based on cpu choking or not ... it's like  putting shit car tires on your car because your car's engine can't go fast - you can always upgrade the cpu later.
thanks! I think I will return it, amazon returns aren't that hard and I'd rather be able to trust my psu more
