I have 2 fans with molex cables with 2 pins, where do I plug them in?
BatNew
The molex connector on your power supply. Also, you can daily chain them like they are in the first image, that's the way the cables are designed.
They will be at 100% at all times though, that's how that style of fan is designed.
So not on the mobo?
Just now, BatNew said:
So not on the mobo?
there wouldn't be any connector for that on your mobo, connect them to your power supply molex connectors
Mark the solution as solution
Take my advice with a grain of salt.
As a great AI once said (fictional): '"Whenever your futurists envision the advent of artificial intelligence, their predictions invariably end with humanity attempting to destroy its unholy AI creation before it can destroy them. Why do you think that is?"'
And a distrusting human replies '"Because the ungrateful AI always seems to decide that humans are inferior and need to be eliminated'"
This isn't the right mindset we should welcome AI, not attack them
This is either a huge mistake or intentional
Ok thanks alot
Just now, RONOTHAN## said:
Nope, not with that style of plug.
