Random stutters for a few seconds
PoPet
I have random freezes/stutters for a few sec for a pretty long time now, I tried everything I could think of, updated my bios to the newest, a fresh windows 11 install (but had this issue with 10 too), and I use the latest drivers. Before the BIOS update sometimes my windows become unresponsive or idk how to describe it. I could change between aplications, but nor my desktop icons, or anything in programs worked. Forexample I could alt tab out from a game to Brave but could open anything in it, so I had to restart my PC. Since I have the newest bios, these kind of crashes did not happen.
Before i updated my bios I couldnt see any wierd things on graphs in afterburner or task manager, the temps were normal (CPU idle around 40C and hits 70C while gaming, GPU around 75-80C). Once I saw my system drive hit 100% usage for a few seconds, i dont know if a failing SSD can couse something like this or not.
With the newest BIOS, I can see my CPU jump to 100% usage for about 3 seconds when these stutters happens.
My config:
AMD Ryzen 5 3600XT stock with PBO enabled
MSI B450 Tomahawk (Bios:
7C02v1I)
PATRIOT VIPER 16GB(2x8) 3200MHZ CL16 - PV416G320C6K with XMP profile 2
Gainward GeForce RTX 2060 PHOENIX GS
FSP Hyper S 500W
Sys drive: Western Digital 256GB Black WDS256G1X0C M.2 PCIe (I've been using it since ~2017)
Any ideas what can couse this problem? I have a feeling about my CPU being the issue since I had nothing like that with my old 2600 and nothing I do software wise looks like helping at all, but I dont know anymore
Latest chipset drivers downloaded from AMD directly?
Checked SSD health?
A couple more questions asked here:
  • Main PC: AMD Ryzen 9 5900X - EK AIO 360 D-RGB - Arctic Cooling MX-4 - Asus Prime X570-P - 4x8GB DDR4 3200 HyperX Fury CL16 - Sapphire AMD Radeon 6950XT Nitro+ - 1TB Kingston Fury Renegade - 1TB ADATA SX 6000pro  - 512GB ADATA SU800 - 1TB Seagate Momentus 5400rpm 2.5" - Seasonic PX-850 850W  - custom black ATX and EPS cables - Fractal Design Define R5 Blackout - Windows 11 x64 2022 - 3 Arctic Cooling P14 PWM PST - 5 Arctic Cooling P12 PWM PST
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight with Tiger Ice - White Shark Spartan X (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Laptop: Acer E5–575G-386R 15.6" 1080p (i3 6100U + 2x4GB DDR4 + GeForce 940MX + 256GB nVME) Win 10 Pro x64 22H2 - Logitech G305 + AAA Lithium battery
  • Networking: Asus RT-N18U - SpeedPort Plus - 35/7 Mbps vDSL - TP-Link TL-WA850RE - TP-Link 5-port 1Gbps switch
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon RX 5700XT - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
I'll double check the chipset driver when i get home, but as far is I know yes, and also check the drive health.
Also I think I'll install a fresh windows on my SATA SSD, and if I wont get the same issue with it, I can tell if my WD M.2 is near its end or something else causes the problem.
Checked SSD health?
I now have the latest chipset drover from 2/28/2023 and checked my system drive. Hard Disk Sentinel says its performance is 100% and health is 53%. I run an error scan with HD Tune Pro and it says 0.0% damaged blocks. Gonna leave them running for the time I play tonight so they might see something if i have freezes again
Still had 1 stutter with the new chipset driver but it was shorter then usually and only happened once in 3-4 hrs, the only thing i could see is my CPU jumping up to 100% for that time
