Any ideas on where I can cut costs without losing performance? Any way to increase performance without increasing costs?
Go to solution Solved by SorryClaire,
1 hour ago, Jayson Meribe said:
I will be using pytorch to work on machine learning generally.
So Tensorflow-like algorithm, mainly on CUDA. Got it.
PCPartPicker Part List
CPU: Intel Core i5-13600KF 3.5 GHz 14-Core Processor  ($296.49 @ Amazon)
CPU Cooler: Deepcool AK620 ZERO DARK 68.99 CFM CPU Cooler  ($69.98 @ Amazon)
Motherboard: MSI MAG B660M BAZOOKA DDR4 Micro ATX LGA1700 Motherboard  ($129.99 @ Amazon)
Memory: G.Skill Ripjaws V 128 GB (4 x 32 GB) DDR4-3600 CL18 Memory  ($289.99 @ Amazon)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($129.99 @ Adorama)
Video Card: MSI GAMING TRIO GeForce RTX 4090 24 GB Video Card  ($1614.98 @ Newegg)
Case: Fractal Design Pop Air ATX Mid Tower Case  ($88.98 @ Newegg)
Power Supply: Gigabyte UD850GM 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($128.98 @ Newegg)
Total: $2749.38
Generated by PCPartPicker 2023-03-29 08:10 EDT-0400
Do be noted that this is a fringe topic in this forum and this should be taken with a grain of salt as im trying to learn what makes each common ML work tick.
Do you need 64GB of RAM? What is the use case for this PC anyway? Please be more specific. And where's the SSD?
Not an expert, just bored at work. Please quote me or mention me if you would like me to see your reply. **may edit my posts a few times after posting**
CPU: Intel i5-12400
GPU: Asus TUF RX 6800 XT OC
Mobo: Asus Prime B660M-A D4 WIFI
RAM: Team Delta TUF Alliance 2x8GB DDR4 3200MHz CL16
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
Case: Phanteks Eclipse P360A
Cooler: ID-Cooling SE-234 ARGB
OS: Windows 11 Pro
Pcpartpicker: https://pcpartpicker.com/list/wnxDfv
Displays: Samsung Odyssey G5 S32AG50 32" 1440p 165hz | AOC 27G2E 27" 1080p 144hz
Laptop: ROG Strix Scar III G531GU Intel i5-9300H GTX 1660Ti Mobile| OS: Windows 10 Home
If you're in the market for a 13900k, 64GB of RAM, and a 4090.. you're in blank check mode not cost savings mode.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 850 EVO 250GB | WD Green 1.5TB | Windows 11 Pro
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 16.3.1) | iPhone XR (iOS 16.3.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4| Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i7-7600U | Seagate 500GB HDD | 16GB DDR4 | Windows 10 Enterprise | HP EliteBook 850 G4
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 | Samsung 850 EVO 250GB | macOS Catalina Lenovo IdeaPad P580
Heavy +1. This is exactly why you have to outline the budget and purpose of a machine, to avoid this exact thing.
Also, i see your 1st PC listing on your profile. There's a lot of lives left in AM4 with 5700X and 5800X3D which would save us a lot in not having to move platform and changing to DDR5.
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  ($187.99 @ Amazon)
CPU Cooler: Noctua NH-D15S 82.52 CFM CPU Cooler  (Purchased For $0.00)
Thermal Compound: ARCTIC MX-2 4 g Thermal Paste
Motherboard: MSI B450 GAMING PRO CARBON AC ATX AM4 Motherboard  (Purchased For $0.00)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3000 CL16 Memory  (Purchased For $0.00)
Storage: Seagate FireCuda 2 TB 3.5" 7200 RPM Hybrid Internal Hard Drive  (Purchased For $0.00)
Video Card: ASRock Phantom Gaming OC Radeon RX 7900 XT 20 GB Video Card  ($799.99 @ Newegg)
Power Supply: Corsair RM750x (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $0.00)
Case Fan: Noctua A15 PWM 140 mm Fan  ($23.94 @ Amazon)
Total: $1100.90
Generated by PCPartPicker 2023-03-29 02:54 EDT-0400
This would be my build oriented around 1440p. You can definitely skip the case swap by removing the front panel of the case, i only did it because its a solid front panel that doesnt have that much air to breathe for intake.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Self Introduction and Current Rig
Hi, have you seen Hoshino Ai recently? Shes not missing, i just thought you should search her on the Internet.
Mostly machine learning work and a little gaming
Total: $1100.90
I made that build several years ago. It's no longer what I am aiming for.
So it was pure planner that you didnt pull the trigger on? I see.
Also, what Machine Learning algorithm? Do you know what its system requirement is and where you or other user struggle on? Does it support external parallel computing API like CUDA?
Total: $2749.38
That's a sound build for their use case, well done.
Maybe some savings could be made by going for an AM4 CPU, but then they'd leave perf on the table for games.
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
