Advice on fps with 4k display
andybeech
Hi so i know so many people have their own opinions on this. I have a 4k monitor currently and like to play beamng and gta v mainly I use my native resolution which is 4k but i feel this is taking a lot of fps performance away would i benefit from going down to 1080 on my main resolution but using the 4k monitor? Or would it make no difference eg beamng runs around 30-50 fps in 4k
specs 2070 rtx windforce oc
i5-8600k 16gb ddr4
windows 10
thanks
Gaming rig: Windows 10 Home 64bit Gigabyte z370 hd3p Intel I5 8600k 16Gb Corsair Vengeance DDR4 240gb SSD & 1tb HDD Sound Blaster z, 2070 RTX windforce, Cooler Master Cosmos Case
Stream rig: Windows 10 Home 64bit, Gigabyte GA-970A-DS3, Amd FX 6100, 12gb mix ddr3 ram, 1060 3gb gtx windforce oc, avermedia c985, 120gb ssd, 500gb HDD,
why not 2560x1440?  better then 1080 but will get you more fps then 4k
Will that come under the normal resolution list, ill have a look too thanks
If you run 1080p, performance-wise, it will always give you a 1080p performance whether you run it on the native 1080p or 4k panel (it will just run at 1080p pixels and stretched it to fit the larger monitor)
It will just compromise your image quality. Not only you'll lose the sharpness that 4k give but any render at monitor none-native resolution will look noticeably blurry (even at a higher resolution like 1440p)
Like you said it's a matter of preference. I personally drop settings before playing under 60 fps. If the game supports it, turn on DLSS or FSR on their quality preset for a minimal hit to image quality. If the games don't support that, turn your graphics from ultra to high. High often looks almost the same but with a lot better performance.
CPU: AMD 5600X - Motherboard: ASUS B550-E - GPU: RTX 3080 10G - RAM: 24GB DDR4 3600MHz CL16 - PSU: Corsair RMx 850W - Storage: 500GB boot drive + 2TB storage SSD - Cooling: custom water loop - Case: O11 Dynamic - Fans: NF-A12x25 - AMP/DAC: FiiO K5 Pro - OS: W10 Pro - Monitor: LG C2 42" - Mouse: Logitech G Pro - Keyboard: Logitech G915 TKL - Headphones: Beyerdynamic Amiron Home - Microphone: Antlion ModMic
i5-8600k 16gb ddr4
windows 10
thanks
Basically, you have a 1440p card that you are trying to Push 4k through. Anything less then 16g of ram is going to have issues with 4k.  There is a good Video on YT comparing a Geforce 4070ti against a little Arc A770.  They demo under certain loads how the limited memory or memory bandwidth causes issues.  The Arc actually beat it in some areas because of the 16ram.
Think of GeForce cards this way,
xx60 1080p, entry 1440p.
xx70 1440p, scratch 4k.
xx80 4k entry
xx90 4k Sell your Children for it.
xx80 4k entry
HUB did a video on that. To be fair though, the losses in performance is very minimum and the issue of micro sutter is barely noticeable in real world and only in some very selective titles.
I am hard disagree with HUB in that regard of any 4k card should have 16GB of RAM. You are paying for every bit of that extra hardware and unless it makes a different in a game you play right now, I am not a big fan of giving people extra hardware that may or may not be necessary. I'll rather have a cheaper card even if it come at 10-12 GB
19 hours ago, andybeech said:
i compromise in this order
dlss/fsr high
play on medium
1440p windowed (1440p or 1080p full screen the sharpness change is noticeable)
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Hey, I own a 2060, using a buddy 3060 presently to push my 27: 1440p  I just bought my daughter am Arc A770.  I am by no means an advocate of all expensive hardware.  I am praying for Intel's Battlemaster to bring the rumored performance and at a worth price.
However... I do believe that GPUs have reached a certain threshold that is going to change the current New GPU every 4 years to 6 or even 8 years.  GPY makers probably know this too and are preparing.
1440p doesnt seem to be in the resolution list?
