need some help
Hextex
i just builded my 1st pc , but i dont know why it doesnt turn on . when i turn on the power supply power button just starts flicking and nothing happens . i could really use some help
more info would be helpful. what components are you using and what is new and whats used?
Also what do you mean by the button starts flicking. The button on the back of the PSU shouldnt move or make noise other than when you switch it on yourself
all component are new .
asus tuf gaming x670e plus wifi motherboard
amd ryzen 9 7900x
32gb corsair dominator ram
deepcool LT 720 water cooler 360mm
amd radeon rx 7900xt
msi a850gf 850w PSU
and plus 6 more fans
i did everything with manuals and all ,but when i turn on the power supplies button the pc case power button led just starts flicking and nothing happens more
maybe a bit more clarification on whats actually going on (like a vid maybe)
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
amd ryzen 9 7900x
msi a850gf 850w PSU
what do you mean by 'flicking'? can u take a video of it 'flicking'?
Current parts list
It looks like something might be connected wrong. Double check all of your front panel connections - power button, power LED, drive LED, reset button etc.
If it's still happening, disconnect all of the front panel connectors, with the exception of the power button connector and try again.
If it works fine, you can start connecting other things back and trying it, one by one.
If you still have the same problem, disconnect the power button to see if the same thing still happens with none of the front panel connected. If yes, then your problem is deeper.
so it seems the problem is deeper  .because i already tried it with the front panel connectors
Ok, at this point you can double check all of the power connections both on the power supply and the motherboard.
You can also try disconnecting all the power cables from the power supply itself (leave the main power in connected), then flip the switch on the power supply, if you hear any clicking from the power supply itself with everything disconnected then it has a fault and needs to be replaced.
If you don't hear anything it could still be the power supply or a problem with the motherboard, either way testing it further will require replacement parts.
I fixed it .... yeeees .the problem was simple but nerve wrecking :D the second MB cable wasnt seated all the way in the PSU :D thats everyone for the help
