Which will be better for 3700x
keavlar
Hey there.
Quick question , For quiet work and gaming, as well as for best long term performance:
1.CoolerMaster Hyper 212 White LED Turbo Cooler
2.Antec Symphony 360 ARGB White CPU Liquid Cooler
3.CoolerMaster ML240L V2 ARGB White Liquid Cooler
I am looking for a white CPU cooler, which will also work in dimension of the corsair RAM dominator
CPU - AMD 5800XMotherboard - ROG STRIX B550-E GAMING , Memory  - G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3600 ,
GPU - NVIDIA GeForce RTX 3080 Ti MSI SUPRIM X 12G,  Case - 4000D AIRFLOW Tempered Glass Mid - Tower ATX Case - Black ,
Storage - Samsung 970 EvoPlus 500GB - Samsung 870 EVO 1TB + 6TB HDD,
PSU - Corsair HX1000 , Display -  ASUS TUF Gaming VG27A 165HZ + Dell 24 UltraSharp Monitor , Cooling - Noctua NH-D15 Black ,
Keyboard - Razer Stalker , Mouse - Logitec G502 Wireless , Operating System - Win 10 Pro ,
Sound - Logitech Z906 5.1 THX Surround Sound Speaker System
Hyper 212 is for 65w CPUS and under, 3700x is more then that so its Not usable here. I would recommend the Arctic 360 AIO over the Antec, but if you want a 360, but you are going from a  25$ (that they are charging 45$) cooler to a 135$ cooler.
White Cooler wise you can also see what deepcool has, they are very reliable.
In terms of noise, a large AIO is the way to go for bursty workloads like gaming and typical office work. This is because the water in the AIO can "heat soak" for a while before the AIO itself gets hot - there's a ton of thermal mass there. If you're doing long renders or big project builds that lock the CPU to 100% for extended periods of time, the advantages are less, but still present.
If you just care about noise, and aren't concerned with cost, then one of the AIOs would be the way to go.
A Hyper 212 can easily cool a 3700X. It is an 88W part at 100% load stock, and a Hyper 212 can handle that. It just isn't going to be as quiet while doing so.
