System Issues after adding nVME - Swap Motherboard or Full upgrade - 3700x -> AM4 or AM5 or ???
Emmortal
So I've come into an issue that seems to be forcing an upgrade on me. Just not really sure how much of an upgrade I need or should go for.
Note that I'm in Canada, so any costs will all be in CAD, with canadacomputers being my dealer of choice.聽馃槒
My System:
CPU: AMD Ryzen 7 3700x
Motherboard: Gigabyte AB350 Gaming 3
RAM: 32GB Corsair Vengeance LPX 3200MHz (4x8GB) - currently only running 16GB - see issue below.
GPU: Gigabyte RTX 2080 Gaming OC
Monitor: Dell S3422DWG Ultrawide WQHD 3440 x 1440
PSU: Corsair 750 watt
OS: Windows 10 Professional x64
Primary use is a mix of gaming (survival and RPG's mostly, with the occasional AAA title), productivity, and occasionally some 3D modeling and game programming.
The Issue:
This arose when I picked up a WD SN770 2TB nVME SSD. What (I thought) should have been a quick upgrade--install drive, move any drives off now-disabled SATA ports, reboot, profit--turned into an entire evening of headaches, troubleshooting, and a rather sore ass from sitting on the floor under my desk for most of the night.
I installed the M.2 drive, moved my existing drives off the SATA ports which would be disabled per the manual, powered on the system, and was met with a system that wouldn't even post. It just turned on for about 15 seconds and restarted, and would do this forever (when I first bought this board, it did this about 3-4 times then started normally) if I let it. It would never even get to sending a signal to the monitor.
Troubleshooting Steps Taken
  1. Reseated the video card - No Post
  2. Removed and reseated the RAM - No Post
  3. Disconnected secondary HDDs from the SATA ports - No Post
  4. Removed the new nVME drive -Posted & Booted to Windows聽馃槃
  5. Reset BIOS to defaults and re-installed nVME - No Post
  6. Removed nVME drive, updated bios (F51b -> F52i) -Posted (Reset BIOS Defaults, Re-Enabled XMP Profile) & Booted to Windows
  7. Re-installed nVME - No Post
  8. Removed nVME - System doesn't go into the restart loop, but now just sits with no signal to monitor
  9. Removed nVME, Removed battery (20+ minutes), cleared CMOS, - no change聽馃が
  10. Removed all but 1 stick of RAM -Posted (Reset BIOS Defaults) & Booted to Windows
  11. Re-installed all RAM - System doesn't restart聽馃が
  12. Removed 2 sticks or RAM -Posted (reset BIOS defaults, no XMP) & Booted to Windows
  13. This is where I'm at right now posting this
Thoughts:
I've had a few issues with this Motherboard since setting up the system originally with a Ryzen 5 1600. Every upgrade seems to cause instability and takes hours to troubleshoot but does eventually stabilize.
That said, I'm thinking it's time to ditch the Motherboard. I'm just not sure if I should:A) swap out the board with something more reliable and robust orB) suck it up and do a full system upgrade to an AM5 board with new CPU & RAMC) suck it up and do a full system upgrade to Intel
I know AM5 is the way forward for this platform, but do you think there's still some significant life in AM4?
I'm aware this will eventually come down to if I want to spend $200 or $1k, so really looking for opinions, but if someone has some insight or solutions into the issues with my current setup I'd gladly save the $$$ for now. I WOULD very much like to be able to use the nVME I just bought but returning it is an option.聽
