HP Pavilion Tg01-0023w Won’t Turn On
Go to solution Solved by The 8-Bit Time Traveller,
52 minutes ago, MattyNice99 said:
I was wondering if it was normal for this computer to not turn on after the RAM, CPU, GPU, and storage has been removed. I plugged up the power cord to the power supply and I pressed the power button and the computer won’t turn on.
Here are additional resources if needed:
https://support.hp.com/us-en/document/c06693646#AbT0
It is normal for a system not to boot if you have removed any one of those three components.
I have to assume that you took them out and put them back for some reason, if this is the case, make sure that everything is seated properly. If any of those components are not making full contact, the system will fail to boot.
how will it turn on? there is no cpu or ram so the computer has no way to operate tasks
