Ryzen 2600, Asus prime x470-pro, G-Skill Trident Z 32GB 3200mhz
I upgraded my RAM a while back to a G-Skill Trident Z 32GB kit. I enabled DOCP/XMP to run the 3200mhz speeds. It ran pretty stable for over a year. When I upgraded to windows 11 I started noticing random game crashes and BSOD's.
I did some initial trouble shooting and upgraded my motherboard BIOS version to the latest version. It ran stable for about 3 weeks and started to show the same symptoms. A fresh windows install didn't fix the issue.
It's really weird, I can use my pc with normal workloads like browsing, coding, etc. without any hastles.
I noticed that I can play games normally without any crashes after a reboot, but when I open my browser and I play a game it would crash after a while but not in a consistent pattern. It crashes at random intervals. A restart fixes it and only if I don't open my browser.
I have reinstalled and verified the game files.
Below is the error I am getting when I view the error in event viewer (All my games give a similar error):
Faulting application name: DCS.exe, version: 2.8.1.34667, time stamp: 0x63a31163
Faulting module name: edCore.dll, version: 2.8.1.34667, time stamp: 0x6390d1f1
Exception code: 0xc00000fd
Fault offset: 0x0000000000171617
Faulting process ID: 0x0x2B00
Faulting application start time: 0x0x1D957428840C288
Faulting application path: D:\SteamLibrary\steamapps\common\DCSWorld\bin\DCS.exe
Faulting module path: D:\SteamLibrary\steamapps\common\DCSWorld\bin\edCore.dll
Report ID: e358a903-35c5-4790-b674-098adbd12d1e
Faulting package full name:
Faulting package-relative application ID:
Faulting application name: Subnautica.exe, version: 2019.4.36.870, time stamp: 0x6271351f
Faulting module name: UnityPlayer.dll, version: 2019.4.36.870, time stamp: 0x62713573
Exception code: 0xc000001d
Fault offset: 0x000000000020a445
Faulting process ID: 0x0x2268
Faulting application start time: 0x0x1D95D9C08033E3E
Faulting application path: D:\SteamLibrary\steamapps\common\Subnautica\Subnautica.exe
Faulting module path: D:\SteamLibrary\steamapps\common\Subnautica\UnityPlayer.dll
Report ID: 1475a098-f5c0-4ab8-91e8-8656b1e65ee5
The last step I am going to try is remove the DOCP/XMP profile and run it stock out of the box.
I have reseeded the RAM sticks.
Any other suggestions are appreciated.
PC Specs:
  • Ryzen 2600
  • Asus Prime x470-pro
  • G-Skill Trident Z RGB 32GB @ 3200mhz (2 x 16GB in slots 2 & 4)
  • 500W Power supply
  • Nvidia GTX 1070 TI GPU
  • 1TB HP nvme SSD (OS drive)
  • 2TB HDD
My next move would be to reinstall windows using a new installation media. Upgrading from windows 10 to 11 (instead of installing windows 11 with a usb stick) is known to be unstable.
I'm not an expert or a professional and I make mistakes. Expand for common PC building advice, a short bio and a list of my components and other tech. I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need.
Common build advice: 1) Buy the cheapest motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother.
useful websiteshttps://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
He/Him
I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 3 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). While I believe I have an decent amount of experience in spec’ing, building and troubleshooting computers, keep in mind I'm not an expert or a professional and I make mistakes.
Favourite Games of all time: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii
Main PC: https://uk.pcpartpicker.com/user/will0hlep/saved/d6GkD3
Secondary PC: https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P
TrueNAS Server: https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C
Laptop: 13.4" ASUS GZ301ZE ROG Flow Z13, WUXGA 120Hz, i9 12900H, 16GB DDR5, 1TB NVMe SSD, 4GB RTX 3050 Ti, TB4, Win11 Home, Used with: 2*ThinkPad Universal Thunderbolt 4 Dock, Logitech G603, Logitech G502 Hero, Logitech K120, Logitech G915 TKL, Xbox Elite Wireless Controller Series 2, Logitech G PRO X Gaming-Headset (with Blue Icepop in Black), {specs to be updated: two monitors}
Other: LTT Screw Driver, IFIXIT Pro Tech Toolkit, Playstation 1 SCPH-102, Playstation 2 SCPH-30003, Gameboy Micro Silver OXY-001, Nintendo Wii U WUP-001(03), Playstation 4 CUH-1116A, Nintendo Switch OLED HEG-001, Yamaha RX-A4A Black AV Receiver, Monitor Audio Radius (4*90s, 1*200s, 2*270s, 1*380s), TP-Link TL-SG105-M2, Netgear GS308, IPhone 14 Pro Max 128GB Space Black, Secretlab TITAN Evo (Black SoftWeave Plus Fabric), 2*CyberPower BR1200ELCD-UK BRICs Series, Samsung 40" ES6800 Series 6 SMART 3D FHD LED TV, UGREEN USB 3.2 Gen 2 10Gbps M.2 NVMe SSD Enclosure, SABRENT 3.5" SATA drive docking station
i'd try just reseating the ram first (and CPU if there was ever a cooler swap or maintenance)
this kind of behavior can be anything, extremely hard to pinpoint. You're focused on ram but we can't be sure.
It could even be bugs with the control software for the rgb on them. are you using asus' or gskill's stuff?
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
I used the built in reset Windows feature to reinstall windows.
I haven't installed the rgb software as yet. I only installed the necessary drivers like Nvidia, Realtek audio and the default drivers Windows automatically downloads.
All is pretty much stock.
I might have fixed it with reseating and swapping the ram sticks (slot 4 -> 2 and 2 -> 4).
I haven't encountered a crash or bsod since swapping the sticks. I'll keep monitoring and post on here if the same symptoms appear again.
Thanks for the suggestions. I really appreciate it 🙂
I've always found that the built in reset feature is kind of useless and that many issues tend to persist after using it. Hopefully the issue is fixed, but if you do find the problem isn't solved, I suggest creating a new windows 11 installation media and installing from scratch.
He/Him
