How to Deal With "Trusted Platform Module Has Malfuctioned"
Here's how this thing happened: I forgot the origin password of the desktop that I'm using in the lab, as well as the answers to safety questions, and I changed the password in terminal with command:
net user [<UserName> {<Password> | *}
And then I found that all accounts linked on Microsoft 365 were logged off. I tried to logged in Microsoft 365 on OneDrive and Outlook but I could not log in with my university account. The PIN for unlock the desktop was also failed. The error is shown in the fig, which says Trust Platform Module has malfunctioned and the error code is 80090016.
I googled the solutions and I tried some of them, like deleted the files in NGC folder, but it  only worked on resetting the PIN. I really need my university OneDrive on this PC because I storage most of the research resources on it so that I can work from home.
I want to know if there are other reliable solutions, and I also want to ask if it can solve the problem by completely resetting the desktop.
BTW the OS is Windows 10 pro for Workstations, and the desktop is a DELL Precision 5820.
You say you are using the laptop in the lab of a university? Ask the uni's tech support for help.
You tried to manually alter the password and now the password & PIN do not match the records held in the TPM.
Other than that it seems a little suspect that someone using a lab PC would forget the login details and all the security questions, possible after a break of many months maybe, why did you not inform the labs IT department that you had forgotten your login?.
Server message: Keyset does not exist
At this point you will have to reinstall Windows.
When you ran the command:
It erased the TPM keyset of your computer.
That's TPM for you....
I run Windows with TPM disabled in BIOS exactly because of BS like this.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
he stole it xd
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3D / ASRock Challenger RX 6750 XT PRO OC 12GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / Be Quiet! 750 Watt 80 PLUS Gold PSU / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / 3x iiYama 1440p 165HZ Montitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 2850MHz core, 2312MHz Memory w/ 25%W increase (265W)
7 minutes ago, Blqckqut said:
he stole it xd
It is possible...
Ok I make it more clear: The desktop/workstation belongs to our lab so it is not a university property. I inherited it from a former student in our lab, so I didn't set up the password or the safety question answers, and I only used PIN to unlock. I contacted university IT but they didn't solve the problem. I don't have to lie on this since I still need this machine to work.
