Can I use 2 or 3 PCI-e cables to power the RTX 4090 instead of 4 PCI-e cables?
Can I use 2 or 3 PCI-e cables with pigtail connector to connect the +12VHPWR 4x 8 Pin PCI-e cable
I have Corsair RM1000x (2021 triangular grille) and only have 3 PCI-e 6+2 cables with pigtail connector
edit: Which PCI-e should I use or doesn't matter
CPU: AMD Ryzen 7 5800X3D                                  RAM: G.SKILL Trident Z Neo 3600Mhz 32GB (2 x 16GB) F4-3600C14D-32GTZNA Timing 14-14-14-34
Mobo: ASUS TUF GAMING B550-PLUS                 GPU: Asus ROG Strix RTX 4090 OC Edition
Case: Fractal Design Torrent                                  Storage: WD_Black 2TB SN850 NVMe
PSU: Corsair RM1000X 2021 (triangular grille)
You can use the pigtail connectors. It doesn't matter which of the PCIe/CPU connectors on the PSU that you use, they're all the same.
Isn't this going to burn the PCI-e on the PSU?
The RMx uses HCS terminals and 16 AWG wires to the first connector, so it's fine
but in Corsair Type 4 cables it says 16 AWG/ 18 AWG  so which one?
It's 16AWG to the first connector then 18AWG to the second connector.
it's fine for the 16AWG but what about 18AWG second connector?
The cable to the second connector only needs to carry the power for the second connector. 18AWG is fine.
last question is cablemod  8 pin PCI-e to 8 pin PCI-e 16AWG or 18AWG?
just as a clarify I'm connecting 3 cables, last one daisy chained and from what I understand from you Spotty and seon123 it's safe to do for long time
