6800XT BUILD - ROOKIE
Budget (including currency): $1700
Country: USA
Games, programs or workloads that it will be used for: APEX LEGENDS, video/audio editing, voice acting, STARCRAFT, and TWITCH/YOUTUBE/FACEBOOK streaming.
Aiming for high FPS 1440p gaming with 4k capabilities.
Decided on building around a 6800XT and 5800X3D. Also decided on a Corsair 4000D Airflow ATX Mid Tower Case.
I have bought my monitor already. ASUS TUF Gaming 27" 2K HDR Monitor (VG27AQ1A) - QHD (2560 x 1440), IPS, 170Hz
Need Motherboard, Cooler, Power Supply, OS, Storage, Memory and MNK.
Can anyone assist with providing a good build? This will be my first build, I have never dove into technology like this before. Thank you.
Are you saying this as in you already have the 5800x3d and 6800xt + case?
If so then something like this would work
PCPartPicker Part List
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor (Purchased For $0.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler ($40.90 @ Amazon)
Motherboard: MSI MPG B550 GAMING PLUS ATX AM4 Motherboard ($159.99 @ Best Buy)
Memory: Neo Forza FAYE 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory ($68.99 @ Newegg Sellers)
Storage: Crucial P3 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($112.99 @ Amazon)
Video Card: ASRock Phantom Gaming OC Radeon RX 6800 XT 16 GB Video Card (Purchased For $0.00)
Case: Corsair 4000D Airflow ATX Mid Tower Case (Purchased For $0.00)
Power Supply: Corsair RM750e 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.99 @ Amazon)
Total: $482.86
Generated by PCPartPicker 2023-03-19 12:08 EDT-0400
i will of course recommend by original build-
https://pcpartpicker.com/list/zh4jTn
i have left a buffer for mouse and keyboard and also as my original post, i would recommend getting a windows 11 key from CDKEYOFFER.COM. CPUs right now have gotten so ridiculously fast for gaming that unless you run a 3090TI on 1080p, a modern i5 will keep up quite well.
but if you insist on the 5800X3D-
https://pcpartpicker.com/list/xVrLGL
this is same to the first list but is based around the 5800X3D instead of the i5-12600k and in this list u get ur wish as your case being the 4000D airflow
Yea the 5800X3D im reading has been paired a lot with the 6800XT for gaming performance.
Total: $482.86
No I don't have those three parts yet, but they are the ones that I decided to build around
Then its time to switch around priorities. DAWs and Starcraft benefits a lot from CPU but Apex and Streaming is pretty GPU bound and we would probably want NVENC for the latter. Could you specify your priorities here?
Press quote to get a response from someone! | Check people's edited comments! | Be specific!  🏳️‍⚧️ Rights
Self Introduction and Current Rig
https://pcpartpicker.com/list/nxZPC6
better gpu with $150 buffer for OS and MnK.
look, im telling you, you would be wasting your money buying a 5800X3D because alder lake is cheaper and still fast enough and you can upgrade to the 13600k later without changing your motherboard which is even faster than the 5800X3D. by getting the 12600k i have been able to get a 6900xt witch is a lot faster than the 6800xt in EVERYTHING and it wont be CPU bottlenecked.
also the list has 32GB of RAM cuz games now need that much, has a better PSU and has a better SSD than the other lists.
as i said previously, it would be worth waiting to see what performance the new generation of GPUs can offer at this price range
if u still go for the 5800X3D and buy into a worse, completely dead platform, at least i tried
 Share
