ALERT - Linus Tech Tips, Tech Quickie, Tech Linked Youtube Channels Hacked ×
Surge protector or ups i dont know the difference and which one to get i live in Florida so lots of power outages due to hurricanes and just storms
shokoji
 Share
Go to solution Solved by GeorgeMKane,
Surge protector would probably be your best bet for now, until you can save up more for a really high performance UPS. The UPS just allows you to save your work and shut down your system properly within so many minutes. Surge protectors work differently.
https://www.cdw.com/content/cdw/en/articles/hardware/surge-protector-vs-power-strip-vs-ups.html
I would probably recommend something like this for now.
https://www.amazon.com/APC-11-Outlet-Protector-SurgeArrest-P11U2/dp/B017VXU6GG/
You want a higher joule rating, especially for a gaming setup, whether you have just a pc or even a gaming handheld/console hooked up to it, as well.
Budget (including currency):  150
Country: usa , florida
Games, programs or workloads that it will be used for:
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): my pc has a 600W powersupply and 3070 and i7k 12th
how do i know how many joules or W they should handle should it be the same as my PC or less is fine or has to be more
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
If you have a lot of power outages then a UPS, and you'll need one able to output about twice as much power as your system is likely to use to at best get 10 minutes of time to safely shut down the PC when power fails, especially when you consider ideally you'll need your monitor plugged into it too so you can see what you're doing.
Router:  Intel Celeron N5105 (pfSense) WiFi: Zyxel NWA210AX (1.44Gbit peak at 160Mhz 2x2 MIMO, ~900Mbit at 80Mhz)
Switches: Netgear MS510TXUP, Netgear MS510TXPP, Netgear GS110EMX
ISPs: Zen Full Fibre 900 (~915Mbit down, 115Mbit up) + Three 5G (~500Mbit average down)
Folding@home Live Stats  Folding@home Recent WUs
Youre going to need a UPS but youre not really getting anything good at 150$ without it just immediately dead within 3 minutes. You could try to find a Back UPS 900VA BVN900M1 model also from Schneider Electronics APC. It has surge protection only up to 490J but honestly i wouldnt go for it especially when 40$ more would get you BVK1200M2 which would give you theoretically around 7-10 minutes.
Press quote to get a response from someone! | Check people's edited comments! | Be specific!  🏳️‍⚧️ Rights
Self Introduction and Current Rig
 Share
