Is an rx6650xt a good choice to go with over an rtx 3060 for my build upgrade?
Go to solution Solved by SteveGrabowski0,
2 hours ago, 10m10s said:
Mostly gaming I doubt I'll be streaming anytime soon as I have a intel core i3 10100f with 32gb ram so I don't think the i3 could handle much streaming.
6650 XT by a mile. It's roughly 15% faster than a 3060 12GB when paired with a high end cpu but with a lower end cpu like a 10th gen i3 Nvidia's problems with higher DirectX12 overhead might really start to show. AMD's DX12 drivers are far superior. I know Nvidia got this reputation for better drivers because for years their DX11 drivers had way less overhead than AMD's which made Nvidia perform better on lower end cpus but the situation has taken a 180 and AMD has the upper hand on driver overhead now on DX12. Only real downside of the 6650 XT is the 8GB of VRAM, but at this performance level that's not too much of a concern IMO.
Just now, 10m10s said:
My budget is 350£ in the UK so Idk wether to pick an rtx 3060 oc 12gb model or to go with an amd radeon rx 6650xt.
if your streaming then going with an nvidia card is highly recommended. So if you are streaming then go with a good price used 3070 over in ebay. If not and your just using it for gaming then over the 3060, the 6650 xt is marginally better but if you can raise your budget by about 35 pounds then go for this 6700 xt that is miles better than both and sometimes trades blows with the 3060 ti and even 3070. This is new on amazon btw.
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
Depends what cpu you have but personally the 3060 oc 12gb is very good as I'm going to get that model too soon. 6650xt isn't bad at all but the drivers are up and down and not stable. But not bad. So I would say 3060
15 minutes ago, Ryuikko said:
For what uses? Generally the 6650xt is going to be faster in gaming as well as usually being cheaper as well
I have an Intel core i3 10100f and 32gb ram
Yeah I think I'll manage with the 8gb vram since I went from a gt710 2gb to a gtx1650 4gb now to an rx6650xt so I think it will be good for the next year or two.
