Noise reduction without breaking the bank
Solved by PDifolco,
4 minutes ago, Karim Bizid said:I did.. The tools for it aren't really ideal in this Gigabyte board so that isn't a really perfect solution.
The PC is mainly running daily tasks but does some gaming from time to time.. Therefore I might be a bit (too) carefull with pulling the fans down all the way...
Install FanControl
https://github.com/Rem0o/FanControl.Releases
Put your fan at say 50% flat you won't hear it
