All-New Echo Dot (5th Gen, 2022 release) vs Tribit upgraded max sound plus
14 minutes ago, Shohan000 said:
Which one should i get .echo dot or tribit.
Is echo dot sound good.
I would like to use voice assistant.
Or should i get tribit .if it sound quality more good
The Tribit is just a plain Bluetooth speaker — it won't support any voice assistants. The Echo Dot sounds good for the money; it won't be stellar, but you'll likely be happy. And it's a true smart speaker with Alexa.
What's your budget?And is your phone Android, or an iPhone? I ask because those may present more options. If you have an iPhone, for example, you could get a HomePod mini (normally more expensive, but you do get more).
I use android
Tribit can be used wirh google assistant I heard
Alexa is 49 doller
and tribit is 42 doller used like new Amazon
1 hour ago, Shohan000 said:
I use android
Alexa is 49 doller
I don't see mention of Google Assistant support in the Tribit product description, so I wouldn't count on that. It's really a portable speaker that might happen to work decently indoors; the Echo Dot is a true smart speaker.
I'd still lean toward the Echo Dot. It might not be as powerful and isn't portable, but it won't necessarily sound worse (it may have a more balanced sound) and will be much better if you want a voice assistant.
Thank you i decided to take dot  echos
