ALERT - Linus Tech Tips, Tech Quickie, Tech Linked Youtube Channels Hacked ×
Help! Need recommendations for water cooling hardware
ChiDolphin12
 Share
Good evening (or morning whoever is reading this),
I recently bought a used graphics card off of r/hardwareswap with the intention of receiving an air-cooled card so it could just be a plug-n-play upgrade. However, I was sent a card that shipped with a water block attached. I'm not complaining about the free upgrade, but now I have to buy hardware to cool the darn thing.
Anyone have recommendations for custom water cooling equipment?
In need of everything but the gpu waterblock and cpu waterblock (not currently interested in watercooling my cpu atm).
EKWB
https://www.ekwb.com/
Refresh before you reply
Alphacool, often cheaper than EK and the guys are super nice & helpful
But they mostly deserve Europe, may be hard to find elsewhere
www.alphacool.com
Anyway, you need
A pump and a reservoir, a small DC and small res will be enough, or you can get a combo pump+res
A rad, at least 280mm (quieter) or 360 (better perf) with fans, I'd recommend Arctic P12 or P14 (3-pack)
Enough tubing for 3 tubes (block to pump to res), so max 1.5m
Min 6 fittings, but I'd also get an additional pair and put a drain between them, will ease maintenance if you don't have an easily accessible res for refilling
System : AMD R9 5900X / X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 / RTX3080 Gigabyte EAGLE GPU/ Phanteks P600S case / Customized Watercooling Eisbaer 280mm + Eiswolf2 360mm + VPP755 pump  and 150mm reservoir0.5TB Sabrent Rocket + 2TB WD SN850 NVme Gen4 + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/ 34" 120Hz 3440x1440p Alienware AW3420DW monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse
Thanks to both of you, I will take y'alls suggestions and keep them in mind
 Share
