ALERT - Linus Tech Tips, Tech Quickie, Tech Linked Youtube Channels Hacked ×
Mid-range system unplayable stutters on GTA V
Arinijus
 Share
Hey people! After Trying to troubleshoot myself for quite a few hours, I've resorted to my last hope - a forum post.
I've got a Ryzen 7 2700X, 16GB of RAM, and a 1660Ti on an MSI Bazooka B450M V2 motherboard with the latest BIOS, all under windows 11. I've re-installed GTA V last weekend, and got unplayable levels of stuttering and a low framerate (can't hit 60!) in both online and story mode. This wasn't an issue the last time I've played it on the same system roughly half a year ago. I've checked the temps (both CPU and GPU at roughly 60 degrees Celsius, which is completely acceptable). I've tried running it all on minimum settings, no improvement (as a test I also maxed each setting and occasionally got a better framerate?). I've looked online and tried limiting the framerate to below 170 fps, no improvement. I tried running compatibility mode on the .exe as that helped someone, not me though. I'm completely stumped, what do I do?
As a sidenote, another game I have the same issue on is Euro Truck Simulator 2. Max or minimum settings it still runs below 60fps. All other games like Apex legends etc. etc. run completely fine and are playable.
I have uploaded a video to MEGA for showcasing my issue (no download needed, has a built in video player.)
https://mega.nz/file/HjITTBpI#nFoaDt2AcDOw6GcS2e8cmUW3KqhBMihI0TdA31-O_QA
Any and all help is appreciated! Would be amazing if I could enjoy these 2 great games again. Cheers!
Have you tried doing a clean reinstall of the Nvidia driver? I had an issue like this (many moons ago on an old and weak GT 635) and doing a clean install of the driver fixed it. In retrospect, I'm guessing it was an issue where a driver update borked some setting in the Nvidia control panel.
I've updated my graphics drivers yesterday via GeForce experience. Let me try wiping it in safe mode with DDU and I'll report back.
Try DXVK. https://github.com/doitsujin/dxvk/releases/tag/v2.1
Download dxvk-2.1.tar.gz
Extract dxgi.dll and d3d9.dll from 32bit folder into ../steamapps/common/Grand Theft Auto IV/GTAIV
Op i'd say try with DDU and then reinstall the latest stable driver
Latest chipset drivers downloaded from AMD?
  • Main PC: AMD Ryzen 9 5900X - EK AIO 360 D-RGB - Arctic Cooling MX-4 - Asus Prime X570-P - 4x8GB DDR4 3200 HyperX Fury CL16 - Sapphire Pulse Radeon  RX 5700XT - 1TB Kingston Fury Renegade - 1TB ADATA SX 6000pro  - 512GB ADATA SU800 - 1TB Seagate Momentus 5400rpm 2.5" - SAMA Armor Gold 750W  - custom black ATX and EPS cables - Fractal Design Define R5 Blackout - Windows 11 x64 2022 - 3 Arctic Cooling P14 PWM PST - 2 Arctic Cooling P12 PWM PST
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight - White Shark Spartan X (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Asus Xonar U5 - Sennheiser HD 560s - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Laptop: Acer E5–575G-386R 15.6" 1080p (i3 6100U + 2x4GB DDR4 + GeForce 940MX + 256GB nVME) Win 10 Pro x64 22H1 - Logitech G305 + AAA Lithium battery
  • Networking: Asus RT-N18U - SpeedPort Plus - 35/7 Mbps vDSL - TP-Link TL-WA850RE - TP-Link 5-port 1Gbps switch
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon R9 380X 4GB - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
Alright, after removing them with DDU and installing the latest ones I don't see any improvement unfortunately
Yup, gave this a shot, no luck.
Let me try this, I think I've only updated these through MSI's site way back.
geforce experience is hot garb, just install it from the website
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDEA
Setup:
Ryzen 7 5700X / ASRock Challenger RX 6750 XT PRO OC 12GB / ROG STRIX B550-F Gaming / Be Quiet! Pure Rock 2 FX CPU Cooler / Be Quiet! 750 Watt 80 PLUS Gold PSU / Sharkoon TK5M Case / 4x16 GB Kingston FURY RAM / 2x 1TB FireCuda BESKAR Edition / 3x iiYama 1440p 165HZ Montitor / Shure MV7 / GK61 Keyboard / Logitech G502-X Mouse
Just did, no difference.
odd, wich platform is gta on
Setup:
another thing i found out, i got insane stutters till i turned off TAA/SMAA, try that
Setup:
Seems like the chipset drivers did something, or it's just placebo. My framerate does spike momentarily to around 70-80ish fps, but it's still usually quite low (40-50, inconsistent overall). The 1% lows are less than 20 fps.
what quality are you on?
Setup:
On epic, I'd usually stick to steam but I've only got the game here.
I don't think it's the graphics settings at this point. I've had everything low/off and I had pretty much the same performance when I had all settings maxed out. Better safe than sorry though.
thats weird, maybe try seeing your temps while doing it, maybe you need to repaste the gpu/cpu, maybe verify files on epic too
Setup:
Verified files yesterday, temps are roughly 60 degrees Celsius CPU, and 73 degrees GPU on the hotspot (checked with HWMonitor).
Attaching my graphics settings below. Pretty intense, but I want them to be stable, at least 60+ while looking nice.
what happens if you turn everything down to lowest, and slowly test out graphics settings? or run benchmark test and see whats best
Setup:
check the temperatures of both the cpu and gpu as well as the clock speed of both cpu and gpu while the issue is happening
tried the benchmark, seems like it only dipped below 60 on the driving part, everything else ran really well!
checked, they are all fine as I've said before, clocks also are stable. Attaching HWMonitor stats while driving around.
strange... maybe @191x7 could shed some light on this (yes 191x7 u are now my go to person for this)
Setup:
I feel like cpu util should be more than 6% with maxes of 18% for this game.
But I am not sure what to do about that. Maybe save anything you have open and then set cpu priority of gta5 to realtime in task manager, see if it improves. There's a small chance it will cause instability, but you can just restart if you cant close the game.
Interesting shout, don't know what to do about it either though. Went online and tried setting the priority to realtime. CPU floats at around 10% usage for the most part while driving around the city.
Now I must not disappoint...
@Arinijusthose 16GB of RAM, is that 1x16GB, 2x8GB, 1x8GB+2x4GB or 4x4GB? Is it running an XMP profile?
Please post CPU-Z screenshots of all tabs (or the validation), GPU-Z and PassMark RAMMon screenshots and check your drives with Hard Disk Sentinel.
Also, check all your drivers with IOBit Driver Booster.
Also, my go-to tweaks are - disable Multiplane Overlay MPO and use InSpectre to disable Spectre and Meltdown mitigations.
Is the game on an SSD?
RAM is 1 stick of 16GB, single channel unfortunately. Had this as a prebuilt in 2019, didn't know any better. I've enabled XMP in the bios though.
CPU-Z screenshots added below, and the RAMMon exported file. System is not on a big load (discord, chrome, etc.) 🙂
Tried IObit, found some slightly old bluetooth and network drivers.
The game is on a Seagate Barracuda 1TB, same one it's been installed before and ran fine. I'll check it's health just in case.
RAMMon - SPD Info.html
 Share
