What case fans would you recommend for an rx 6700 xt and ryzen 5 7600x
Go to solution Solved by RONOTHAN##,
Arctic P12 are some pretty good options for the price, you can get a 5 pack for $35 and they perform pretty well.
Had my eye on either the noctua nf-f12 ippc or the cougar vortex cf-v12hpb (cougar just because it is cheap and quiet)
if you know any better fans, please recommend them but make sure they will fit in a Corsair 4000d airflow
NF12 IPPC aren't meant to be case fans unless you live in a factory, they're super loud
Dunno about Cougar
But I'd say just get a pack of Arctic P12, RGB or not, they're cheap but effective and silent
System : AMD R9 5900X / X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 / RTX3080 Gigabyte EAGLE GPU/ Phanteks P600S case / Customized Watercooling Eisbaer 280mm + Eiswolf2 360mm + VPP755 pump  and 150mm reservoir0.5TB Sabrent Rocket + 2TB WD SN850 NVme Gen4 + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/ 34" 120Hz 3440x1440p Alienware AW3420DW monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse
That's exactly what i did, i ordered directly from Arctic since they live next door 😄
Ordering directly from European manufacturers is easy when you live next to them.
Noctua is also very close and i ordered directly from them in the past as well.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
 Share
