Updated the VBios from MyAsus on my laptop, was a mistake, Help
TronZeroJB
 Share
So, I did a hard reset recently since I used that debloat script and blocked the windows updates, and to remove the effects, I had to hard reset, but sure, it was fine, I uninstalled the armory crate, and went on to update the Vbios, but guess what, I get an option to eject my GPU and as much googling I did about it, it was not a harmful thing if I did eject, I just have to restart, but it doesn't stop there, I see no response in task manager, no waking up of GPU in games unless I specifically choose the GPU in benchmarking software, it's dead. I then reinstalled Armoury crate, changed back some settings hoping that would fix it, and, it did make the GPU a little more active but this time, random spikes of activity and back to extreme power saving for some reason. I tried calling Asus and they made me download their team viewer app, but, nobody called back for a week now. the screen just goes blank for a second on startup. and I cannot uninstall the crate that takes up so much memory until I get a call back from Asus. I have no idea how to revert to old bios or what is causing this issue in the first place. Maybe I disabled something important? I used the debloat script from Chris Titus Tech. I am out of options here, do I do another hard reset?
Simple questions:
Do you have the latest System BIOS available?
Did you try to reformat and Install Windows 11 from scratch enabling UEFI, disabling Legacy and enabling Secure Boot?
You prob have mux switch or bios set to integrated gpu only.
I have armoury crate where I can set it to ultimate and the GPU goes bananas with 140Ws, I did that too
On 2/6/2023 at 2:14 PM, Catalonia said:
Simple questions:
It happened exactly after a complete windows 11 hard reset, UEFI is enabled, Secure boot too
 Share
