4070 TI Adapter cable
Bozzwoliks
 Share
Hi
Just finished with my first build in over 15 years and going for an all white theme and just wondering if anyone knows if you can get the power cable for the 4070 Ti in white?
Thanks
47 minutes ago, Bozzwoliks said:
Hi
Thanks
hi!
(one of my friends build his pc last week and he also has the 4070ti aero and corsair 4000D elite case, and i think you also have a 240mm white corsair aio, so youguys almost have the same pc😅)
but now your question:
my friend has a lian li (sfx) 850W psu, which has a native 12+4 pin connector and all white cables,   NOTE!  THE 24-PIN CABLE IS TOO SHORT, SO YOU NEED AN EXTENDING CABLE!
but you can also get an extension cable for 20 bucks or so.
and btw, my friends 4070ti doesnt work with the included power adapter, does yours just work like that?
Cable mod may have what you are looking for.
My PC Specs: (expand to view)
CPU: Intel Core i7-10700K - OC to 5 GHz All Cores
CPU Cooler: Corsair iCUE H115i RGB Pro XT (Front Mounted AIO)
Motherboard: Asus TUF GAMING Z490-PLUS (WI-FI)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600
Storage: Intel 665p 1 TB M.2-2280 NVME SSD (x2)
Video Card: Zotac RTX 3070 8 GB GAMING Twin Edge OC
Power Supply: Corsair RM850 (2019) 850 W 80+ Gold Certified Fully Modular
Case: Corsair 4000D Airflow
Case Fan 120mm: Noctua F12 PWM 54.97 CFM 120 mm (x1)
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x4)
Monitor Main: Asus VG278QR 27.0" 1920x1080 165 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
Mouse: SteelSeries Rival 600 Wired
Keyboard: SteelSeries Apex 5  – (Hybrid Blue Switch)
Headphones: SteelSeries Arctis 9X Wireless - Black
Speakers: Mackie CR3-X 3 Inch Speakers Pair
UPS: APC 1500VA UPS Battery Backup and Surge Protector
Tell nvidia thats a 4060 and to refund you the difference
AMD Ryzen 5 5600 | MSI B450 Tomahawk | Corsair LPX 16GB 3000MHz CL16 | XFX RX 6700 XT QICK 319 | Corsair TX 550M 80+ Gold PSU
Yet it usually beats the 3090, sometimes coming close to the 3090 Ti in performance (or beating it in pure compute and AI).
Yes its overpriced, but the argument of its model number not making sense is invalid.  It absolutely was wrong to call it at 4080, but 4070 Ti is perfectly valid.
Router:  Intel Celeron N5105 (pfSense) WiFi: Zyxel NWA210AX (1.44Gbit peak at 160Mhz 2x2 MIMO, ~900Mbit at 80Mhz)
Switches: Netgear MS510TXUP, Netgear MS510TXPP, Netgear GS110EMX
ISPs: Zen Full Fibre 900 (~915Mbit down, 115Mbit up) + Three 5G (~500Mbit average down)
Folding@home Live Stats  Folding@home Recent WUs
Nah bro it's the same situation as the 1060 3GB. It was a 1050 ti and i will die on this hill. The 1050 ti they actually gave us would be classified as a 1050 super by today's standards. Looking at the specs it's a 4060 through and through. The AD-104 chip has no place in a x70 class card (this is also an issue with the 1070 and 970 don't get me wrong).
Ever since the first titan came out they shifted the stack so x70 and x80 have become midrange but are still being sold at high end prices.
Which ultimately they are free to do, its up to us to assess what were about to buy.  Its not like they've ever been entirely consistent in their naming schemes, neither has AMD, especially as you get to the lower end.
At the end of the day you buy the card which does what you need.  I ended up with a 4070 Ti as I wanted a card for AI upscaling, with Folding at Home on the side, that supported AV1 encoding and used less power than the 3080 it was replacing - while costing less than a 3090 Ti.
I'd not argue that PC gaming is pricing people out of the market, it clearly is, but there's a lot of reasons for that.  NVIDIA have been pumping a ton into R&D to get us raytracing and AI, die shrinks no longer decrease cost the same they used to, and of course the big problem is once they started the price hikes, its hard to go back as their responsibility is not to get as many people to buy cards as possible, its to get the maximum profit for the shareholders.  If that means less people buying more expensive cards, that's what they'll do, its what they HAVE to do or risk being sued by their shareholders.  Its why all businesses are at risk of becoming toxic once they start selling shares as its inherently an unsustainable business model long term when the shareholders want ever increasing profits and the customers don't have ever increasing funds to buy with.
4 minutes ago, Alex Atkin UK said:
-snip-
So I should just sit there and take it like the "good consumer puppy" I am, meanwhile having to shell out more and more and more and more and more money each year if I want to get the performance range I want?
Then again, I think I'm too cynical about this as the performance delta between the tiers is still big enough to warrant segmentation. It would also be in their interest to not water down the whole stack so you only get 1% better performance per tier increase. Like even though it's a midrange chip, the performance on x70 cards is still good enough compared to older x70 cards before the titan was introduced.
Its more that we have no choice, there is no "little guy" to come in and undercut these big corporations (which is how Capitalism was supposed to work to avoid prices going out of control like this) and they all have the same constrains as huge companies with shareholders.  The same reason Intel may never make it in the GPU space, as its costing them so much in R&D and unless it pays off quickly, shareholders get antsy and will force them to shutter the project.  There just way too much greed.
I'm not anti-capitalism, but this is what people refer to as late-stage Capitalism.  Where the businesses have gotten so big, expecting so much profit, that sooner or later they either collapse or price most of us out of the market.
 Share
