need help with my GPU fan
 Share
Newly bought this new rx 6600 and it great. But the problem is that I can’t control the gpu fan. It can only go 0 rpm and full blast when temp goes above 57 degree. Already tried Msi AB and Radeon software but no luck and both the curve and fan speed slider doesn’t seem to work. Is this a feature or something wrong with my card.
Full specs:
Ryzen 7 1700
16gb ram
Asrock B450m pro f
MSI RX 6600 Mech 2X
500W PSU
you might have to use adrenalin to disbale 0 fan first?
So yu tried the fan curve in fans settings area not just the slider, and when trying the slider you clicked on the gear icon nx to it
sorry for late reply. Already tried that multiple times but still the fan only goes up and down between 57 degrees
The gpu may have a switch on it, on one of the length sides usually, for a default bios and a "OC" bios etc... try switching it to that if it does have one. Afterburner should still be able to control the fans at least though either way. Are you hitting the apply button on AB after you make your changes? Are you saving them to a profile?
my gpu don’t have any switch at all and i have already hit apply every time i change the setting but still nothing work
Did you check the bios version?
Could it be that it has some custom mining bios on it or something?
Where'd you get the card?
Intel i5-7600K  | Cooler Master Hyper 212 Evo  |  MSI H110 PC MATE  |  2x8GB Crucial Ballistix LT Sport 2400MHz  | Palit GAMEROCK GTX 1080 8GB |  Dark Base Pro 900 (Orange)  | HITACHI 250GB 2.5" Drive - Game Drive | HITACHI 250GB 2.5" Drive - Game Drive | Crucial MX200 250GB 2.5" SSD - Boot Drive |
Living Room PC: AMD Ryzen 2400G | VEGA 112x8 GB Crucial Ballistix 2400MHz | Samsung 120GB SSD | Seagate 500 GB HDD | Node 202 + 450W PSU |
bought it from a local store. Here card infomation
Try contacting MSI support? Maybe they could help ?
Maybe your AMD software (where you can also control the fan) is overwritting your MSI Afterburner setup?
 Share
