Problem with Ryzen 7 2700X and MB Gigabyte B450 DS3H
Hello guys,
I have a very strange problem with my pc . It gets in bootloop. Just restarts no chance to get into bios.
First it was doing just fine , works fine , have 16Gb of RAM in dual channel , all ok, NVMe drive , Ryzen 7 2700x CPU ,RX590 RedDevil, Gigabyte B450 DS3H motherboard (my suspicion is that this motherboard is faulty) as I saw on forum that this motherboard has problems with VRM ... I did not buy this motherboard I got it for free, so I wanted to make this pc for my nephew , as I already have good pc for me.
It was fine when I instaled OS Win 11 on it , everything was fine but when I instaled Valorant (my nephew plays this) , anticheat Vanguard asked to enable bios safe boot so I have done this but after that all went to hell. Not able to boot and also not able to enter bios again. Also tried to clear cmos but no success also take out of battery for 5 days did not help.
So anyone has a hint what to do ?
The new Bios probably has Secure Boot on by default.
How did you install Windows 11 without Secure Boot? A modified installer?
  • Main PC: AMD Ryzen 9 5900X - EK AIO 360 D-RGB - Arctic Cooling MX-4 - Asus Prime X570-P - 4x8GB DDR4 3200 HyperX Fury CL16 - Sapphire Pulse Radeon  RX 5700XT - 1TB Kingston Fury Renegade - 1TB ADATA SX 6000pro  - 512GB ADATA SU800 - 1TB Seagate Momentus 5400rpm 2.5" - SAMA Armor Gold 750W  - custom black ATX and EPS cables - Fractal Design Define R5 Blackout - Windows 11 x64 2022 - 3 Arctic Cooling P14 PWM PST - 2 Arctic Cooling P12 PWM PST
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight - White Shark Spartan X (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Asus Xonar U5 - Sennheiser HD 560s - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Laptop: Acer E5–575G-386R 15.6" 1080p (i3 6100U + 2x4GB DDR4 + GeForce 940MX + 256GB nVME) Win 10 Pro x64 22H1 - Logitech G305 + AAA Lithium battery
  • Networking: Asus RT-N18U - SpeedPort Plus - 35/7 Mbps vDSL - TP-Link TL-WA850RE - TP-Link 5-port 1Gbps switch
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon R9 380X 4GB - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
Test the system by disconnecting the drive from the board, start it and see if you can get into the BIOS.
If so, Valorant messed up a setting somewhere and if not it's probrably a board/BIOS problem.
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
I tried with disconnected drive also , doesn`t work either.
regular instalation , update from win 10 to win11 . But when I activated some secure boot stuff it went wrong... And now not know how to fix it
When switching to Secure Boot you have to enter Safe Mode on first login and then regular mode, otherwise the OS might creash (BSOD) after booting.
But you say you can't boot or enter Bios, so it resets on POST. That is a hardware issue.
I don`t know if I am able to update the bios only from usb flash drive, without starting the pc , without drives and ram...
Yes, if it doesn't want to go into the BIOS with the drive disconnected it's a hardware problem - I'd bet Valoriant did something, borking the board's BIOS since Win 10 and 11 will write a bit of info to it for "Validation" purposes (Tying the OS copy to the board).
That's what I make of it right now.
I would try another MB different from gigabyte b450m ds3h, just to try. It is hard that the CPU died.
remove you ram, remove cmos and start pc, so if it get like auto restart put all back and i think it sholud boot into bios
 Share
