Help me to choose the better motherboard
Hello,
Planning to build a new PC. I saw couple motherboards but I don't know which one to buy.
1st Mobo: Asrock A520M-HDV
2nd Mobo: Asrock A520M-HVS
3rd Mobo: ASROCK B450M-HDV R4.0
The reason for choosing those asrock mobotherboards is because they're cheap and I can't give more money for motherboards.
I think the B450 is a better chipset.
I think the A series boards are a chipset lesser.
Synthesizer thread:
LTT Fan Fiction:
Bad
Bad
and meh + old
Whats the budget?
What are the other specs?
The asrock is unlikely to have a ryzen 5000 capable bios
4 minutes ago, jaslion said:
Bad
Bad
and meh + old
Whats the budget?
Budget for the mobo is 70euro
Ryzen 5 4500
16gb ram either adata or silicon power
Psu deepcool pf500
Rx 580 (used)
Bios updating is not a problem for me.
I will take a cpu from my friend
best advice is be patient for a week or two save a little more and start out with a better board.......i have to agree with other posts these boards are not just cheap but not even cheerful.
24 minutes ago, jaslion said:
Bad
Bad
and meh + old
Whats the budget?
I kinda agree here.
I have a b450 and a Ryzen 5600...
If you can, save up the few extra bucks for like a 550 or something.
I only use my b450 cuz I bought it years ago.
Synthesizer thread:
LTT Fan Fiction:
Ryzen 5 4500
Psu deepcool pf500
Rx 580 (used)
Before I continue the deepcool pf is a known component killer due to how badly its made so avoid at all costs.
For 70 euros used a b550 should be available or a msi b450 mortar even
Any sugestion for a PSU ~40 usd
And the country I live used components like cpu, mobo , ram are more expensive than brand new. IDK why.
 Share
