I need help to solve this (Motherboard and screws)
Solved by Beerzerker,
Just now, Justsomeonewho said:Ok, so I just use 7 out of 9 standoffs ? And i put them so that the card doesn’t fold or else, am I right ?
Yes, 7 will work fine as long as those aren't messed up themselves.
Be sure to check their screws to their standoffs before attempting to install the standoffs in the case.
