Can not get system to post after a CPU upgrade from a 2200G to 3600
I recently tried to upgrade my CPU from a Ryzen 2200g to a ryzen 3600. The motherboard is an Asus prime-a320m-k running BIOS version 5603 which should support the new CPU.
When turning the PC on all fans including the GPU fans (gtx 1650) spin and light up but the system refuses to post. The system worked before the upgrade and the CPU is from another system where it too was functioning a few days ago just fine.
So far I have tried:
Removing CMOS battery,
Trying with a new RAM kit,
Checking Motherboard and CPU power cables,
Booting with only power and monitor plugged in in case a USB or other device was causing a weird issue,
Removing the cooler and reseating the CPU along with checking for any obvious damage to both the socket and CPU pins.
I feel like i have exhausted all the usual obvious solutions and was wondering if anyone had any experiences like this with this board and had a potential fix or any other ideas.
Thank you guys and gals.
Just to make sure, you're not plugging your monitor into the motherboards HDMI or VGA?
  • Main PC: AMD Ryzen 9 5900X - EK AIO 360 D-RGB - Arctic Cooling MX-4 - Asus Prime X570-P - 4x8GB DDR4 3200 HyperX Fury CL16 - Sapphire Pulse Radeon  RX 5700XT - 1TB Kingston Fury Renegade - 1TB ADATA SX 6000pro  - 512GB ADATA SU800 - 1TB Seagate Momentus 5400rpm 2.5" - SAMA Armor Gold 750W  - custom black ATX and EPS cables - Fractal Design Define R5 Blackout - Windows 11 x64 2022 - 3 Arctic Cooling P14 PWM PST - 2 Arctic Cooling P12 PWM PST
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight - White Shark Spartan X (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Asus Xonar U5 - Sennheiser HD 560s - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Laptop: Acer E5–575G-386R 15.6" 1080p (i3 6100U + 2x4GB DDR4 + GeForce 940MX + 256GB nVME) Win 10 Pro x64 22H1 - Logitech G305 + AAA Lithium battery
  • Networking: Asus RT-N18U - SpeedPort Plus - 35/7 Mbps vDSL - TP-Link TL-WA850RE - TP-Link 5-port 1Gbps switch
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon R9 380X 4GB - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
might be a daft question but have you updated the bios ?
compatable is one thing but the ability to run is dependant upon the bios being correct.
The display port in plugged into the back of the GPU. The Mouse and keyboard do not seem to be receiving any power either (they have RGB that is not lighting up) which is why i think its just not posting rather than any sort of display error since there is no power from the USB ports too
It is a slightly older version but still several versions newer than what the support site lists as when the CPU first got support on the motherboard. Putting in the old CPU back in and trying to update to an even newer version could be worth a go I guess ,even if it shouldn't be neccisary. Maybe ASUS has its documentation wrong, or the previous update has something up with it.
Gigabyte X570 Aorus Ultra - Ryzen 5600X - MSI RX5700 Mech OC - Corsair Vengeance pro 32GB 3200Mhz - Dual Alienware 2720HF 27" 240hz
Corsair iCUE H150i Elite Capellix - EVGA SuperNOVA G3 850w 80+ Gold - Phanteks Eclipse P500a case
Samsung 980 PRO 1tb NVMe (boot drive) - Samsung 870 Evo 1tb SSD - Seagate BarraCuda 8tb HDD - Western Digital Blue 2tb HDD
no idea but generally updating the bios with a new CPU is good practice as often the bios updates can offer more functionality
I did run the update over ehternet function which is what upgraded it to the 5603 version. I guess its a manual update with a USB needed then since that doesn't seem to pull any updates newer than the one I have.
This is de wey my bruda.
I have had similar issue with my gigabyte boards...using their live uodate from a server has never worked for me? could be i did it wrong but everytime i went to the website and downloaded manually unpacked and placed on a fat32 usb drive it has worked.
Looks like this might be the next step then. I nearly midnight here so will proably have to give it a try tommorow. Thank you all for your advice its appreciated.
you are welcome and as I am in a different timezone good luck and i hope it is resolved for you tomorrow..
Odd, i got mine to F32 on my B450 through that live update function because i was lazy, and it updated for me.
Press quote to get a response from someone! | Check people's edited comments! | Be specific!  🏳️‍⚧️ Rights
Self Introduction and Current Rig
It may well be related to my geo location. Rural district S.China
Also add the term inpatient and consider old habits die hard. Always downloaded and used a thumb drive for as long as I can remember.
 Share
