Motherboards have Too many numbers and letters , help pls
I'm trying to look for a budget motherboard for a i7-12700kf CPU but I read I z series motherboard is best can anyone tell me if should go with a z series or different I don't really wanna spend over 200$ on a motherboard
Check what socket the i7-12700kf is, and go on from there.
There are many resources to find the correct ones with budget, features or mid range in mind
Don' t forget to quote me in replies, or mark answers as solved if it helped
Not just for me, not just for Cheesus, but for everyone ❤️
a Z series chipset would be benificial to get the most out of your CPU. Are you looking for DDR4 or DDR5 boards?
Also, if you can buy the K series version of that chip, having a IGPU is great for troubleshooting reasons.
My Rig: CPU : 10700K | RAM : Trident Z Neo 3600Mhz c16 32G (4x8) | CPU cooler : NHD15 | GPU : ASROCK RX 6900 XT Formula OC | PSU : Corsair RM850 (black label) | CASE : Corsair 5000D Airflow | Storage : Samsung 970 evo 1TB, WD Black 1TB, Samsung evo 850 Sata SSD | Casefans : Lian Li Unifan SL120 7X|
MOUSE : G Pro Wireless X superlight | Keyboard : Ducky one 2 RGB full Cherry MX Red
Z motherboard unlocks overclocking. if you don't wanna spend 200$, skip it.
it will perform as advertized.
Ryzen 5700g @ 4.4ghz all cores | Asrock B550M Steel Legend | Radeon RX580 | 2x 16gb Micron E 2666 @ 4200mhz cl16 | 500gb WD SN750 | 9 TB HDD | Deepcool Gammax 400 w/ 2 delta 4000rpm push pull | Antec Neo Eco Zen 500w
Did not say that
3 minutes ago, Alinz said:
Did not say that
you implied without the z motherboard it will not run optimally.
No, i stated that you will get the most out of your CPU. As we both know a K series CPU is unlocked, that is a feature of set product. A Z series motherboard is required to make use of set feature. Never stated it would not run in spec. However, I can see that it would be confusing.
Overclocking is mostly overrated these days, chips are running pretty close to the margin out the box and the power/temp increase is just not worth it.
yes it is. especially for newbies. paying extra for a feature that may not be used is a waste.
True. I overclock just for fun, after that back to factory or even better lower the power consumption.
90% of the time i don't need the extra boost. (my cpu is already fast enough)
 Share
