Where should I place my GPU radiator?
Solved by Alinz,
than mount the gpu aio either on the bottom or on the side (that would be my preference) with the tube outlet comming from the bottom to ensure your pump doesnt run dry.
2
Vibes NoVibes ·
Posted in Troubleshooting1 -
5
kim921 ·
Posted in Build Logs4
play_circle_filled
Latest From Linus Tech Tips:
Why Do Youtubers Keep Destroying Companies - WAN Show April 19, 2024
