How do I connect this case fan to my pc?
WestTexan
 Share
Its has 6 holes
Next pic is a cable I had in my pc box that I think I used to make this fan work, it has more 6 pin things
Lastly,my only case fan has this wire coming out of it and a 3 pin I connect to sys_fan1
This wire coming from fan 1 can be connected to the cable
B450 tomahawk mobo
Check boxes for a converter.
List fan name/model.
You most likely need some kind of a hub/controler for those fans.
 Share
