I need someone smarter than me on this subject please help
Go to solution Solved by Grayson2000,
2 hours ago, aledsav1 said:
So you can do fresh install of windows 11 on older pcs no issues, there are plenty of guides/videos on how to do it: https://pureinfotech.com/install-windows-11-unsupported-pc/
download windows 11 media creation tool: https://www.microsoft.com/en-gb/software-download/windows11
and follow that guide
but if you just want a windows 10 key cheap, then I always get from here 'electronic first.com' make sure you get the right one pro or home etc..I have bought a few times from them no issues
So if the old hdd have been removed it makes no difference, if the motherboard has a windows key built in but I doubt it as its older pc? then it would just install the key to your new windows instal if it was the same kind, like windows 10 home or pro etc, but you are trying to use a key that was associated with other hardware and microsoft are a pain, there are ways around it
OK I think I’ll give it a try today right now and if you come up with any other thoughts or ideas, let me know and I’ll let you know if it works
OK long story short I have relatively decent knowledge about building PCs I’ve built one and I really enjoyed it for my birthday. My parents decided to get me a used PC off of eBay so I can tinker on it and have a really nice media PC, the PC and the components worked just fine but there’s a Windows key issue when I bought the PC. It had no hard drive in it anymore so I installed a  SSD. And proceeded to try to install windows everything booted up, but it would not except my personal windows pro key. I stayed on the phone with Windows tech-support for about three days straight at about three hours at a time, but they cannot help me with any of it so as of right now I’m having to run Linux Which the PC is running fine on Linux but I would prefer to use windows anybody that can guide me with some advice on if I need to either buy a new motherboard for it or do I have to grit my teeth and yet again by another windows license
where did u get the key from? Is it already being used by a device?
THIS IS MY SIGNATURE
Buy a Windows key, they are cheap ($2 to $20 depending on where you look).
  • Main PC: AMD Ryzen 9 5900X - EK AIO 360 D-RGB - Arctic Cooling MX-4 - Asus Prime X570-P - 4x8GB DDR4 3200 HyperX Fury CL16 - Sapphire Pulse Radeon  RX 5700XT - 1TB Kingston Fury Renegade - 1TB ADATA SX 6000pro  - 512GB ADATA SU800 - 1TB Seagate Momentus 5400rpm 2.5" - SAMA Armor Gold 750W  - custom black ATX and EPS cables - Fractal Design Define R5 Blackout - Windows 11 x64 2022 - 3 Arctic Cooling P14 PWM PST - 2 Arctic Cooling P12 PWM PST
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight - White Shark Spartan X (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Asus Xonar U5 - Sennheiser HD 560s - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Laptop: Acer E5–575G-386R 15.6" 1080p (i3 6100U + 2x4GB DDR4 + GeForce 940MX + 256GB nVME) Win 10 Pro x64 22H1 - Logitech G305 + AAA Lithium battery
  • Networking: Asus RT-N18U - SpeedPort Plus - 35/7 Mbps vDSL - TP-Link TL-WA850RE - TP-Link 5-port 1Gbps switch
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon R9 380X 4GB - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
And free ones (legitimate free ones), at worst install win 10 I believe it's still free upgrade.
11 hours ago, aledsav1 said:
have you tried windows 11?
On the PCs it’s a little bit older it has an
i7 4770k and I don’t believe it meets the requirements for windows 11
Yes, my key is being used. I bought it from Amazon like in 2020 I believe straight from Microsoft you know it came with a little USB and everything.
I was planning on running windows 10 from the get-go is there anyway you can link a legitimate place to buy one and then my next question is once it’s activated will it be sure to take away the watermark because I think the problem is since the previous owner had windows on it he took the hard drive out and it’s still looking for the original key and I don’t know if it makes a difference, but this is an prebuilt PC
if you have used the windows key on another pc I dont think it would work again.
Thank you for your help. I did find a solution everyone was so helpful and I’m so grateful for y’all. This is the first time I’ve ever tried a form and it is been two days and y’all handled it and help me. God bless y’all and have a wonderful day.
your welcome. This place is like that, everyone helps alot and you get responses fast
 Share
