ALERT - Linus Tech Tips, Tech Quickie, Tech Linked Youtube Channels Hacked ×
Replacement for foam that has turned to dust
hayheather
 Share
Go to solution Solved by Needfuldoer,
Look for some self-stick weatherstripping at the hardware store. They sell rolls of the stuff for sealing drafty windows and doors. You can probably find something about the right size and cut it to fit if you really want to.
That foam isn't critical, it's just there to help keep airflow moving the right direction. (So the fan can't suck warm air from near its own exhaust side.) The laptop should work just fine without it.
Hello everyone,
I'm in the middle of repasting my old laptop in an effort to lower temps. Along the edges of the heatsink there is (was) some of that grey foam to try to make the heatsink more airtight. The moment I touched it, it turned into dust. I'm cleaning it off but I'm wondering if anyone has some good ideas for something to replace it? It would have to be nonconductive, compressible, and have a less horrible adhesive if it is self-adhesive.
Thank you!
picture of same model heatsink for reference. Notice the horrific foam/dust/goop on the copper fins on the left side of the picture.
Lenovo IdeaPad Y570 Genuine Heatsink AT0HB002 | eBay
5 minutes ago, hayheather said:
Hello everyone,
Thank you!
If you mean this bubblegum-looking stuff, that's called thermal pads and they have to be there, also you have to use the same thickness as the originals, maybe a bit thicker would work but slimmer won't.
Thermal pads aren't expensive, you get them in sheets and cut them yourself.
  • Main PC: AMD Ryzen 9 5900X - EK AIO 360 D-RGB - Arctic Cooling MX-4 - Asus Prime X570-P - 4x8GB DDR4 3200 HyperX Fury CL16 - Sapphire Pulse Radeon  RX 5700XT - 1TB Kingston Fury Renegade - 1TB ADATA SX 6000pro  - 512GB ADATA SU800 - 1TB Seagate Momentus 5400rpm 2.5" - SAMA Armor Gold 750W  - custom black ATX and EPS cables - Fractal Design Define R5 Blackout - Windows 11 x64 2022 - 3 Arctic Cooling P14 PWM PST - 2 Arctic Cooling P12 PWM PST
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight - White Shark Spartan X (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Asus Xonar U5 - Sennheiser HD 560s - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Laptop: Acer E5–575G-386R 15.6" 1080p (i3 6100U + 2x4GB DDR4 + GeForce 940MX + 256GB nVME) Win 10 Pro x64 22H1 - Logitech G305 + AAA Lithium battery
  • Networking: Asus RT-N18U - SpeedPort Plus - 35/7 Mbps vDSL - TP-Link TL-WA850RE - TP-Link 5-port 1Gbps switch
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon R9 380X 4GB - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
Dell owns my soul.
I was refering to the grey open cell foam on the right side of the picture. It's a little hard to see. Someone else suggested weatherstripping though so I think I might try that
This that I marked in red?
Alluminum tape could do, kapton tape could do, nothing would also do...
 Share
