is 550w Gold power supply enough for a 3060ti (planning to undervolt if necessary)
TraineeGab
 Share
Hi! I'm planning to get a 3060ti but kinda worried about my power supply, most of my friends say that I need to get at least 650w for it to work.
My future upgrades includes adding 2x8 gb ram or replace it with 2x16 and additional storage (probably 1-2 SSD) but for the meantime the GPU would be my upgrade, no plans of getting higher than i5 atm.
Is this enough? if not, what kind of PSU you can recommend me? or what GPU can I go for instead?
I  play League of legends, valorant, minecraft, stardew valley, Payday 2. I wanted to be able to play newer games at high quality images like fallout 76, cyberpunk, etc.
I also do video editing, mostly at 1080p stuff but when I get my GPU I want to start practicing 3d modeling and animation with it.
Type Item
CPU Intel i5-11400
Motherboard Gigabyte B560M DS3H
Memory Kingston hyperx fury 16Gb (2x8gb) 3200 mhz
Storage Kingston SA2000 500 GB M.2-2280 NVME Solid State Drive
Video Card *(Planning to get) 3060 ti
Power Supply Seasonic Focus gx-550w gold modular
Thank you for your suggestion and feedback.
Financial Management Student with interest in Multimedia and Technology.
What I like to do is add up the max power draw of the CPU and GPU combined, and then add 100W as good measure. The 3060 ti can peak to 200W and the i5 says 65W. I'd say it will be enough, usually I wouldn't trust Intel CPU's rated power draw but since it cannot be overclocked, it's gonna be fine.
It will be more than enough.
RTX 3060 maybe won't draw above 200W, especially with undervolt, 11400 while gaming most likely wont even go above 60W, the rest of the system maybe not even 30W.
And, undervolt is not if needed kind of thing, to me, if you could undervolt, then undervolt, it lowers power draw and heat output, it might even give you more performance.
Not an expert, just bored at work. Please quote me or mention me if you would like me to see your reply. **may edit my posts a few times after posting**
CPU: Intel i5-12400
GPU: Asus TUF RX 6800 XT OC
Mobo: Asus Prime B660M-A D4 WIFI
RAM: Team Delta TUF Alliance 2x8GB DDR4 3200MHz CL16
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
Case: Phanteks Eclipse P360A
Cooler: ID-Cooling SE-234 ARGB
OS: Windows 11 Pro
Pcpartpicker: https://pcpartpicker.com/list/wnxDfv
Displays: Samsung Odyssey G5 S32AG50 32" 1440p 165hz | AOC 27G2E 27" 1080p 144hz
Laptop: ROG Strix Scar III G531GU Intel i5-9300H GTX 1660Ti Mobile| OS: Windows 10 Home
To be clear, it's a 3060ti I'm aiming for, is it still valid to say that it won't draw above 200w?
Still valid. That 200W is also for the 3060 ti, and it's the peak, so it will rarely hit that. I think with those components you have chosen, your PC might draw half of that 550W PSU.
Bold assumptions on the CPU, just a quick Googling suggests the CPU can draw up to 140W under heavy load, depending on the motherboard.  It should still be fine, but best not to make assumptions based on the fictional figures the CPU manufacturers claim as they're not REAL power consumption numbers.
Router:  Intel Celeron N5105 (pfSense) WiFi: Zyxel NWA210AX (1.44Gbit peak at 160Mhz 2x2 MIMO, ~900Mbit at 80Mhz)
Switches: Netgear MS510TXUP, Netgear MS510TXPP, Netgear GS110EMX
ISPs: Zen Full Fibre 900 (~915Mbit down, 115Mbit up) + Three 5G (~500Mbit average down)
Folding@home Live Stats  Folding@home Recent WUs
My i7-10700k + 3070 system only pulls 525 watts from the wall including two monitors (as measured from ups). You’re more than fine.
My PC Specs: (expand to view)
CPU: Intel Core i7-10700K - OC to 5 GHz All Cores
CPU Cooler: Corsair iCUE H115i RGB Pro XT (Front Mounted AIO)
Motherboard: Asus TUF GAMING Z490-PLUS (WI-FI)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600
Storage: Intel 665p 1 TB M.2-2280 NVME SSD (x2)
Video Card: Zotac RTX 3070 8 GB GAMING Twin Edge OC
Power Supply: Corsair RM850 (2019) 850 W 80+ Gold Certified Fully Modular
Case: Corsair 4000D Airflow
Case Fan 120mm: Noctua F12 PWM 54.97 CFM 120 mm (x1)
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x4)
Monitor Main: Asus VG278QR 27.0" 1920x1080 165 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
Mouse: SteelSeries Rival 600 Wired
Keyboard: SteelSeries Apex 5  – (Hybrid Blue Switch)
Headphones: SteelSeries Arctis 9X Wireless - Black
Speakers: Mackie CR3-X 3 Inch Speakers Pair
UPS: APC 1500VA UPS Battery Backup and Surge Protector
If given the opportunity, an Intel CPU can draw a ton of power. Limits can be set on BIOS or through the Intel program and it will be fine, I honestly don't think he will miss bursts of 140W if he is concerned.
7 minutes ago, Alex Atkin UK said:
Bold assumptions on the CPU, just a quick Googling suggests the CPU can draw up to 140W under heavy load.
Did try just now to put a heavy load (in my standards) towards my pc. Opened up a youtube 4k video and opened my premiere pro with a project that is a 1080p not much effects but on full quality preview and a minecraft at the side. Shockingly it drew 111w  D: But thanks for this insight.
So TL;DR my 550w power supply is enough for my plans to get that 3060ti?
Could you link your source? I checked everywhere and they all list system power draw, not just CPU.
I have the 12400, from all the reviews I checked for 11400, the power consumption is about the same, and my 12400 never go above 60W while gaming.
Not to mention that gaming won't max out the CPU, so peak power draw means nothing in real world usage, unless he uses the CPU for productivity work.
CPU: Intel i5-12400
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
OS: Windows 11 Pro
Although a decent 550w is enough, Focus Plus Gold 550w has shut down issues with some 3060 Ti cards. Just give it a try. Does it keep running it's fine. A shut down doesn't harm anything but means you need a new PSU.
 Share
