Posted January 29 This is my first time choosing an aio and these look good but i cant find any comparisons online so i came here. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 29 the silent loop 2 has a 360mm rad the pure loop 2 fx has a 240mm rad and rainbowpuke. it's not about better, it's about two totally different product categories. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 30 Author 13 hours ago, manikyath said: the silent loop 2 has a 360mm rad the pure loop 2 fx has a 240mm rad and rainbowpuke. it's not about better, it's about two totally different product categories. but wich one has more performance? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 30 Just now, gertpro said: but wich one has more performance? i'd assume the 360mm rad, if you can fit it in your case. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31 Author 19 hours ago, manikyath said: i'd assume the 360mm rad, if you can fit it in your case. but they both have 360mm rad Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31 1 hour ago, gertpro said: but they both have 360mm rad from what i can find, the "pure loop 2 fx" doesnt. https://www.bequiet.com/en/watercooler/3745 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31 Author 1 hour ago, manikyath said: from what i can find, the "pure loop 2 fx" doesnt. https://www.bequiet.com/en/watercooler/3745 https://www.bequiet.com/en/watercooler/3743 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31 1 hour ago, gertpro said: https://www.bequiet.com/en/watercooler/3743 well, then it's simple: one has rainbowpuke, one hasnt. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31 Author 2 hours ago, manikyath said: well, then it's simple: one has rainbowpuke, one hasnt. That doesn't really matter to me, it just is that the pure loop 2 fx is a little newer and maybe is better because it is newer. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31 They are pretty much the same the FX has RGB Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31 Author 7 hours ago, loonie01 said: They are pretty much the same the FX has RGB Do u know if the location of the pump matters because the FX hast it in the tubing and the silent loop has it in the CPU block Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
