i5 12400f or ryzen 5 5600g for rx 5700xt
So i recently got rx 5700 xt and have i5 9500 but the problem is that the games i play (rdr2 csgo and other) kinda have bottleneck frequently gpu will hover under 65% while cpu is at 100% so thats not good. so the options are i5 12400f or ryzen 5600g(since its cheaper in my local stores). other options are also i5 11th and 10th gen which arent much cheaper than 12th gen. r5 is only 25 dollars cheaper than 12400f. so which one and is smart access memory worth going with amd.
also gonna mention i have 2x8gb stick of ram at 2666mhz, i know thats not fast but if thats not much difference in performance i might keep it. so please any advices would be welcome thank you
The 12400F is the fastest, and it does support SAM as well (SAM is just AMD's marketing term for ReBAR, and it does work on Intel as well with the same rough performance increases).
If the price difference is only $25 get the 12400F no question.
id go with the 12400f
How about an used i7 8700 or an i7 9700? Would not require you to change the motherboard with the CPU.
  • Main PC: AMD Ryzen 9 5900X - EK AIO 360 D-RGB - Arctic Cooling MX-4 - Asus Prime X570-P - 4x8GB DDR4 3200 HyperX Fury CL16 - Sapphire Pulse Radeon  RX 5700XT - 1TB Kingston Fury Renegade - 1TB ADATA SX 6000pro  - 512GB ADATA SU800 - 1TB Seagate Momentus 5400rpm 2.5" - SAMA Armor Gold 750W  - custom black ATX and EPS cables - Fractal Design Define R5 Blackout - Windows 11 x64 2022 - 3 Arctic Cooling P14 PWM PST - 2 Arctic Cooling P12 PWM PST
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight - White Shark Spartan X (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Asus Xonar U5 - Sennheiser HD 560s - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Laptop: Acer E5–575G-386R 15.6" 1080p (i3 6100U + 2x4GB DDR4 + GeForce 940MX + 256GB nVME) Win 10 Pro x64 22H1 - Logitech G305 + AAA Lithium battery
  • Networking: Asus RT-N18U - SpeedPort Plus - 35/7 Mbps vDSL - TP-Link TL-WA850RE - TP-Link 5-port 1Gbps switch
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon R9 380X 4GB - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
 Share
