How to fix anything under pink lines is glitched?
foodmaster
On 1/28/2023 at 12:37 PM, Gokul_P said:
What is your monitor and how old is it
What do you mean by monitor and it's 3 years old.
isnt this a monitor or is it a laptop?
Laptop
Laptop
Is this coluring is also true while booting up  (or in the bios)
what's coluring, sorry I don't really know much about laptop.
The distrotion in your screen "Under the pink line is glitched"
the pink line appear when I start the laptop. After like 2-5 minute, anything under it start glitching.
Thats Good news. Could you booting into bios and see if the pink line appears there. If you say what is your laptop i will check how to enter bios in your laptop
I'm not home right now, I will check it later.
I'm in the bios startup menu, the pink line is still there.
So it is The display (hardware) that is damaged You could try and replace it or send the laptop to manufacturer or a store they replace it for you.
