Overclocking Ryzen 7 1700 with an asrock motherboard A320M-K
Go to solution Solved by RONOTHAN##,
A320 boards do not support CPU overclocking, at least not on 1st and 2nd Gen Ryzen CPUs (3000/5000 series technically do since you can do BCLK OC though that's not really recommended). If you want to overclock, you need to do a board swap to a B- or X- series board
I can only find an ai tweaker, but that only seems to have RAM overclocking, and it is different to other asrock guides that have OC Tweaker
ok Can i overclock ram though?
Even if you could overclock the CPU, I doubt that board could handle much of it.
mY s YsTeM iS Not pErfoRmInG aS gOOd As I sAW oN yOuTuBe. WhA t IS a GoOd FaN CuRVe??!!? wHat aRe tEh GoOd OvERclok SeTTinGS FoR My CaRd??
 HoW CaN I foRcE my GpU to uSe 1o0%? BuT WiLL i HaVE Bo0tllEnEcKs? RyZEN dOeS NoT peRfORm BetTer wItH HiGhER sPEED RaM!!dId i WiN teH SiLiCON LotTerrYyOu ShoUlD dEsHrOuD uR GPUmy SYstEm iS UNDerPerforMiNg iN WarzONEcan mY Pc Run WiNdOwS 11 ?woUld BaKInG MY GRaPHics card fIX it?
 MultimETeR TeSTiNG!! aMd'S GpU DrIvErS aRe as goOD aS NviDia's YOU SHoUlD oVERCloCk yOUR ramS To 5000C18
Yeah, RAM overclocking is enabled on A320 boards. Just don't expect to get very far with that either, 1st gen Ryzen is known for their terrible memory controllers that can't reliably do 3200MT/s
Just now, RONOTHAN## said:
Year, RAM overclocking is enabled on A320 boards. Just don't expect to get very far with that either, 1st gen Ryzen is known for their terrible memory controllers that can't reliably do 3200MT/s
i just want to overclock it to 3000 mega hertz, so that should be fine
 Share
