Ryzen 7 5800X at max clock even when idle
My Ryzen 7 5800X is running at a constant 4.7GHz, and I have no clue why.
The CPU is in an Aorus B450 Elite V2, and I'm using the latest BIOS.
I'm currently using Task Manager and L-Connect 3 to monitor the clock speed.
I appreciate any help in advance!
My current build:
CPU: AMD Ryzen 7 5800X
Mobo: Gigabyte B450 Aorus Elite V2
GPU: XFX Radeon RX 6800 SWFT 319
RAM: Corsair Vengeance RGB PRO (4x8 3200MHz)
Storage: Patriot P300 128GB, XPG SPECTRIX S40G 1TB, WD HDD 1TB
Cooler: NZXT KRAKEN X53
PSU: Corsair RMx 750W 80 Plus Gold
Case: Corsair 4000D
Monitor: AOC 24G2U
Keyboard: Corsair K70 MK.2
Mouse: Roccat Burst Pro
Headphones: Roccat ELO 7.1
Microphone: Roccat Torch
I would check Windows power plan first. If it's set to High Performance it might not allow clock speeds to reduce.
Could also be a bios setting
No software open? some programs force high performance mode
Ryzen 5800X3D(Because who doesn't like a phat stack of cache?) GPU - XFXRXXT
X470 Strix f gaming, 32GB Corsair vengeance, WD Blue 500GB NVME-WD Blue2TB HDD, 700watts EVGA Br
Open Ryzen Master and check individual core clocks there. Task Manager is not accurate in low/minimal load conditions. It does not correctly account for each cores clockspeed in a way that's reflected in that number so unless you're in a full multicore load situation its not going to be accurate.
You could check to make sure it's not set to 100% in your Minimum processor state.
I'd try resetting BIOS to defaults
5950X/3080Ti primary rig  |  1920X/1070Ti Unraid for dockers  |  200TB TrueNAS w/ 1:1 backup
Ryzen Master shows only 2 cores at max clock speed. So I assume that means its actually fine and there is nothing to worry about?
My current build:
Case: Corsair 4000D
Monitor: AOC 24G2U
Is it the same two cores static at 4.7Ghz or is it moving around?
Yeah, its the same 2 cores. The other 6 go up and down occasionally, but only by a slight bit.
My current build:
Case: Corsair 4000D
Monitor: AOC 24G2U
 Share
