Ryzen 5 7600X running hot with 360mm AIO
Is it normal for these new 7000 series CPU's to immediately spike up to 90-95c when running cinebench r23? It's running at almost 5,2ghz.
I also noticed that while gaming my cpu almost clocks up to 5,5ghz and runs cooler, 70c.
Mobo: Gigabyte B650M DS3H
CPU: AMD Ryzen 5 7600X, AM5
RAM: Kingston 16GB (2 x 8GB) FURY Beast, DDR5 5200MHz, CL40
Cooler: Corsair iCUE H150i ELITE CAPELLIX, 360mm
Yes, this is normal behavior.
AMD made the chips run this way, with a 95C target, to squeeze every bit of performance out of them.
01010011 01110000 01100001 01100111 01101000 01100101 01110100 01110100 01101001 00100000 00110100 01101100 01101001 01100110 01100101
   Setup details
MOBO: ASUS ROG STRIX Z490-G GAMING (Wi-Fi)
CPU: Intel Core i7-10700K @5GHz + Corsair H100x
GPU: ASUS ROG STRIX RTX 3080 Ti OC LC @2GHz
RAM: G.SKILL TridentZ RGB 32GB (4x8GB) @3600MHz, CL16-16-16-36
SSDs: Samsung EVO Plus 1TB, Samsung EVO Plus 1TB, Crucial MX500 2TB, Crucial MX300 1.05TB
PSU: Corsair HXi Series HX1200i 1200 Watt 80 Plus PLATINUM
CASE: HYTE Y60 (White/Black) + 2x NOCTUA NF-A14 PWM CHROMAX.BLAC, 3x Corsair LL120 RGB
MONITORs: Samsung Odyssey CRG9, Samsung Odyssey G9, Samsung Odyssey G7 Neo
KB/M: Corsair K70 RGMK.2 CHERRY MX Brown, Corsair Ironclaw RGB + Corsair MM300 PRO Extended
AUDIO: FX-Audio DAC-X6 + beyerdynamic TYGR 300 R, Steelseries Arctis Pro + GameDAC, Corsair SP-2500
Yes, AMD configured the chip to always be close to 95C to maximize performance, you could get it down of course at max performance, but only with the best coolers.
Not an expert, just bored at work. Please quote me or mention me if you would like me to see your reply. **may edit my posts a few times after posting**
CPU: Intel i5-12400
GPU: Asus TUF RX 6800 XT OC
Mobo: Asus Prime B660M-A D4 WIFI
RAM: Team Delta TUF Alliance 2x8GB DDR4 3200MHz CL16
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
Case: Phanteks Eclipse P360A
Cooler: ID-Cooling SE-234 ARGB
OS: Windows 11 Pro
Pcpartpicker: https://pcpartpicker.com/list/wnxDfv
Displays: Samsung Odyssey G5 S32AG50 32" 1440p 165hz | AOC 27G2E 27" 1080p 144hz
Laptop: ROG Strix Scar III G531GU Intel i5-9300H GTX 1660Ti Mobile| OS: Windows 10 Home
Cinabnech Multicore Benchmark hit All cores hence genarate more heat. Gaming on the other hand hit Some cores (Dependant on the game) and generate less heat. amd is pushing the cpu if it has thermal and power headroom for maximum perfomance so this is totally intentional if you want to run it cooler you could underclock it but you loose performance by doing so.
 Share
