Need an entry level build for gaming that is as power efficient as possible
1 hour ago, cookiedragoneh said:The build is for my girlfriends little brother who lives with high functioning autism and has a lot of trouble socialising so I have convinced his parents that a gaming PC might be the thing he needs to help in this regard as he will have full control over if and when he feels like socialising without having to wait for his friends to go home once his social battery has been exhausted, he also seems to like talking about his ideas for games and is constantly talking to me about the things he likes and dislikes about the games he plays so I want to try and encourage him to make youtube reviews on the games he likes as its difficult to find things he's interested in enough to stick to it .
To be absolutly clear here : I'm not a doctor or a specialist in autism. But, I'm myself "atypical mild autistic", which has been identify by specialists of high level, recognized at least nationaly in France. They're NOT complete clowns like psychoanalyst.
I've been in contact with a lot of associations, structures, and other "heavier" cases of autism.
As I encourage strongly your initiative, I've to give fair warnings.
The internet can be a good starting point to work on his social skills. But he still needs to do it IRL regularly, still. It's completly different to socialise IG than IRL. And it's espacially true for autistic cases. As he get more confortable on the internet, which he probably will, he needs to not be completly closed off because of it. Which was and still is the case for me.
The internet can also be very brutal. It can help him as much as it can destroy him. I think he would be a good idea to put some protections on that pc and espacially on thoses youtube and twitch channel if he would like to make some streams and videos. Not saying that he shouldn't take critisim at all, but insults and brutal comments could affect him a lot, even when he doesn't talk about it. Which I think you probably know, but, just to make it clear.
1 hour ago, cookiedragoneh said:Which processor would be best for this task? something in the 7000 series or should I go for an earlier generation? Is a G series processor my best bet or would that be insufficient on it's own for simultaneous gameplay and recording/streaming or does Intel have something better or will i need to get him a GPU?
Concerning hardware, a 5600G could be a good choice for now, as Zen 4 ( 7000 ) and AM5 plateforme as a whole, doesn't have APUs for now, and could be a good starting point for a relativly capable CPU for a more powerful disrcrete GPU down the line, as long as you don't pair it with something ridicoulous like a 4080, for exemple. Not even mentionning the fact DDR5 is still a bit pricy, even if it fairly calm down.
The 5600G isn't a equivalent to the 5600 or 5600X, as it feature half of the cache of its bothers. Which does fairly impact performances.
As I know how minecraft behave with hardware, I don't really know for sure Roblox, and I've no idea for Jurassic World.
Minecraft shouldn't be a problem, as long as RAM speed and timing is correct, which an APU relly on for VRAM of its IGP, and Ryzen CPUs are still scaling well with it anyway, because of infinity fabric. And minecraft tend to love single core performances, which RAM speed will help a fair bit.
Streaming will be probably a challenge still, as the CPU can probably handle it fairly well, but the IGP part might be his hold back here. As GPU's bandwidth is completly saturated, OBS will probably still drop frames, regardless if the CPU is encoding. Windows 10 and 11 is fairly progressing in that domain, executing OBS in admin will probably help, but I would still watch out for that.
1 hour ago, cookiedragoneh said:Would getting him a higher end processor and under clocking it be better for power consumption in the long run or is that just stupid?
Personnally I never recommand anything related to "futur proofing", unless it's pretty much DOA like the 9600k or the whole 11th gen series of intel for exemple. Like it's easy to tell it's not gonna end well. But most of time, "futur proofing" is a bunch of BS, and you should just go by what you need for X budget and X use case, so you have more budget either for mater the most to you, or left overs for much more agressives upgrades.
Agressive upgrade path, even on modest mid-range hardware, will pretty much always slap the crap out of anything high end lasting in an old pc mid to long term AND with a better consistancy on performances on newer games if not just straight up better.
As I understand his use case isn't that intensive, I would still not recommand to go higher end for that "futur proofing", it just doesn't make sens.
I'm not sure about underclocking, it would waste performances, and you probably don't want that, since minecraft does strongly depends on single core performances, which underclocking will obviously impact. But you could undervolt it at stock clock speed ! Note that I strongly recommand to benchmark it at fully stock setting for a reference point and then try to undervolt it little step by little step. Further than pure stability, Ryzen can be "stable" but loose performances if you don't watch out for that.
1 hour ago, cookiedragoneh said:Are there features on motherboards that might drain power unnecessarily other than the obvious RGB or is that negligible?
I would say negligible.
1 hour ago, cookiedragoneh said:Do M.2s use more or less power than traditional SATA SSDs or is that negligible?
Same, negligible. Could have an impact on budget tho.
