Lian Li Galahad 360 - very loud
AzowiX
I have this AIO and that is very loud right now due maybe to one of the fans that has defected and always do some squeaky sounds..
But anyway this AIO is very loud especially on heavy tasks..
Thats possible to disconnect one of the fans of the AIO right now to stop the defective fan or that is risky?
Ryzen 9 5900X CPU.
You should rather define a fan curve to have fans spin slower, but what you should do depends on your temps, so that you don't overheat your CPU
With a 360mm AIO it should be ok anyway
Why don't you replace the failing fan btw?
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Show a picture of how the AIO is installed. "Trickling sounds" sounds a lot more like pump problem the a fan. If the pump is the highest point in the loop, it will suck air, making those trickling sounds. Similar sounds can come also if your radiator is mounted tubes up.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
The radiator are on the top of the case.. and the pump is under..
that is squeaky sounds that right now has stopped.. dont know why... but that is okay to disconnect one of the fans and stay with two only?
