PC Settings - I'm a little confused...
Solved by Naijin,
1 hour ago, Vertikull said:I just upgraded my rig and I decided to go all out. 3090, i7-12700k & 128gb of ram (just cause) but MW2 only runs at about 130-ish frames at 1440 max & Destiny 2 runs at about 140. Am I missing a setting or something? I feel like the 3090 should be able to keep my monitor at its 165hz.
At max settings? Looks about right.
https://www.techspot.com/review/2561-cod-modern-warfare-2-benchmark/
This benchmark from Techspot shows the 3090 running at 118 average at 1440p maxed.
