RTX 2080 Super blackscreen + 100% fan when sustained load
Solved by GuiltySpark_,
Given you've already done the basics, I think its safe to say that card is dead. That's a pretty common failure mode, with the screen going black and the fans ramping to 100%.
Just to be clear though the PC you tested was using your power supply with a 3090Ti?
1
Tom09 ·
Posted in Troubleshooting4 -
EdoTensei ·
Posted in Graphics Cards0 -
6
Helltech ·
Posted in Networking0 -
googlnock ·
Posted in New Builds and Planning8 -
12
1
6
