Help W/ CPU Upgrade
Solved by HelloPeople,
5 minutes ago, Bailey_Dasis said:Hello all, I am hoping for some advice as to what the highest end CPU my current GIGABYTE B450M DS3H motherboard can handle is! I got it on sale a long while ago alongside a R5 2600 and I am hoping to increase my single core performance without going over ~$350 or so. Thanks for any advice in advance! (If there is a micro-atx motherboard and CPU upgrade for under 350 that will still get a significant performance boost please lmk)
you can go all the way to R9 5950X. but you will need to flash/upgrade your bios.
according to the gigabyte specification page here.
