Will I see a noticable difference ? 9900K Upgrade
@jaslion @Origami Cactus@xg32 @Dima Dolgov @SkilledRebuilds @Ralf
Thanks for all the replies.
I have (mostly) read through your messages .
While you don't really agree on everything I still got a feeling for what I can expect if I upgrade.
If I try to summarize what you all have said:
The 9900K is still a "capable" CPU but it is starting to show its age and is noticable slower compared to modern CPUs.
But if I keep my 3080, I would only see about 10-20% difference.
I usually skip 1 generation before upgrading.
I've had GTX 580, GTX 770, GTX 1080 and now RTX 3080.
So I am not looking to upgrade the GPU at the moment.
So right now I am in some boring middle ground.
The 10-20% difference is not enough for me to really consider upgrading.
