RTX 3060 XC fan rattle: What can I do?
mapegl
When my fans ramp up, it will rattle. And as the PC sits on my desk right next to me, it is kinda annoying.
Apparently it is no warranty reason and I can't find viable solutions.
Aren't there any third party coolers that fit? I used to have an arctic cooler on my 7950, but that is not supposed to fit.
A regular fan or two would be great, but the card uses some weird plugs for the fans and I would really, really want to control the fan speed with the GPU itself.
Any helpful ideas? I know I can set a fan curve, but I would like something more permanent.
I am no stranger to modding something a bit as you can see in my old build log in my signature.
PC: AMD Ryzen 5 3600 @4.2HGhz 1.25V || Noctua NH-U12S SE2 || 16GB (2×8GB) Aegis 3000Mhz CL16 @3200Mhz ||
|| Sapphire Pulse RX 6700 10G || MSI B450i Gaming PLUS MAX Wifi
  || Kingston NV1 2TB m.2 ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
What exactly are the wierd plugs on the GPU like?
Maybe its just a compact plug for both fans or just a different size?
I had a similar problem with an older GPU once and I just soldered a desktop fan to the original connector.
Worked great.
Worked great.
Yeah that's my problem. I would have to do that and I would like to keep the cooler the way it is for possible warranty claims.
Apparently the connectors are reversed. I can't find the forum post I found, but somebody already figured out that they changed that for some reason. There are those connectors that just plug into a GPU, but I could cut those and solder them to a regular fan.
How long is the warranty on this card?
One alternative could be liquid cooling. there is likely a waterblock for it and it would keep the stock cooler in stock condition.
23 minutes ago, mapegl said:
if the warranty is not an option, the quickest fix is turning the fan off and ziptieing a fan onto it, other than that, replacement fans can be found, usually more expensive than i'd like though.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
There are some, but not be the usual offenders. Alphacool doesn't make a single one.
Byski or whatever their name is have one and I have no experience with water-cooling.
Also, instead of that I could just switch or even upgrade for the same or even less money.
It did occur to me and thank you for the idea, but it's not worth it.
That could work, but still requires external fan control. Not ideal, but thank you for the suggestion.
Well I guess there are no secret options I didn't know about. To be honest, all the mods are probably equal to just biting the bullet and losing money on a switch...
If you have something like a commander pro in your system, you could plug the fan into this and use the GPU temperature as the temperature source.
Getting one just for that reason, would be really expensive, though
I have sold the 3060 for 330 and for a new 6700 for 400.
I don't care about any of the feature I lost that way and I am gaining performance, so that's fine.
