13900k heat issues
Solved by WoodenMarker,
Temps are normal and perfectly fine.
2 hours ago, jaslion said:A nhd15 can barely cool a 13900k let alone a nhu12s.
Get a better cooler as as of right now its basically thermal throthlling.
No, it's not. The 13900k operating temp is up to 100c.
The NH-U12A is better than the NH-U12S and not far off from the NH-D15.
