MSI Z790 Tomahawk vs MSI Pro Z790-A for 13900KF
Go to solution Solved by PDifolco,
Tomahawk is the tier just above Pro usually, a bit more expensive, better looking and some more features
Both will work but a Pro is kinda cheap looking on a 13900 build 😛
Both will handle it. The question is what are you trying to do with it?
The Pro has a slightly weaker VRM, but it should be fine. It also has worse USB connectivity on the back panel. That's basically the difference.
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
I got a tomahawk can’t fault it
worth the extra just for clear cmos button
-13600kf
- 4000 32gb ram
-4070ti super duper
