"First Build" Need help which ram is better
Solved by Queen Chrysalis,
3 hours ago, MiggyAngeloP said:I see, but wouldn't it be better to upgrade from 16gb 3200 to 32Gb 3600? since I'll be running a bunch of programs, like Android Studio and photoshop. Also for the Modded Server and Modded MC, which has more than 200/300+ mods.
Oh sure, just make sure if you want more RAM to get an identical kit to what you have. I don't know how much RAM modded MC uses, I was under the impression that usually loads the CPU more than anything, but see how it runs, and if you are over 97% RAM util and the game is stuttering, then you could get a second 2x8 kit of Trident z 3200.
