Thermlatake h200 Tg RGB - Which fans go where?
Hi LTT forums!
I have a thermaltake h200 tg rgb with... not the best ventilation, and so was wondering if anyone here could help with my fan orientation/placement. My specs are as follows:
. Intel core i7 9700kf
. MSI mpg z390 gaming plus
. Aorus RTX 2070 Super
. 4 x 16 Trident z gskill 3200mhz ram
. Cooler master MasterAir MA410M RGB Cpu Cooler
My current fan orientation is like this:
. 120mm Corsair 31-003606 PWM (75cfm) fans on both front bottom and middle slots
. 120mm Thermtake TT-1225 RGB (41.6cfm) Front top, Rear, and rear top slots ]
I also currently have 2 140mm Corsair ML140 PRO RGB 140mm Premium Magnetic Levitation Fans (55.4cfm) awaiting arrival. Which I'm not sure if I'll even need them.
Below are some pictures of the setup for better visualisation. Is this an okay setup? when the two 140mm fans arrive, is it worth putting them on, and if so, where?
Just over all as well if anyone has any other suggestions that would be appreciated, I am only 1 or so months into owning this computer and its my first one and so am not the most experienced when it comes to computers. The max ive done is changing fans and plugging in a wifi card so far.
image.thumb.jpeg.bb8dbc17970eaa67ddba8e8c9c278edd.jpegimage.thumb.jpeg.4965efbd74855c1661ebdce0a124c4b4.jpegimage.thumb.jpeg.f5aa556045f1d75c126bacbaf99dc6ba.jpeg
3 hours ago, SniffSniff said:
Hi LTT forums!
fans look fine
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
